It is currently Fri Jun 27, 2025 11:55 am
Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 29  Next
PostPosted: Tue Nov 06, 2012 5:13 pm
Yep, they are the grass alright...
I would have ordered a set for The Cat except they werent available then so I settled for Gaz.
Good work Sean, keep it up!!
Tricky
PostPosted: Wed Nov 07, 2012 8:41 am
Cheers mate
Forgot to add a pic of My super dooper reservoir bracket.. It's super dooper
PostPosted: Wed Nov 07, 2012 7:36 pm
Rubber grommets needed on those fluid lines as they pass through metal....!!??
Tricky
PostPosted: Wed Nov 07, 2012 7:46 pm
Sean just check that alloy bracket for the tanks on meeni incase it needs any mods, from memory those holes in the firewall differ slightly from early to late cars in some way or another.
PostPosted: Wed Nov 07, 2012 8:32 pm
Yeah definitely needs them but I have to get them before I drill too big a hole in it..
Will check that hole alignment! Didn't even think I just assumed the master cylinder bolt holes were all the same
PostPosted: Sun Nov 11, 2012 4:28 pm
Started fabricating my internal gear selector today as well as modifying the rubber mounted selector to solid mount. I thought the full length tunnel would look a little neater with a bit of carpet on it rather then having exposed rods etc.. Will make a bolt on cap for the back of the box as well as weld some tabs to the box for bolting it to the floor, but will do that using meenis floor as this rover one is a different shape.. Gears feel heaps better without the rubber mounted selector!
Looks ugly right now but it won't when it's all done
PostPosted: Sun Nov 11, 2012 4:41 pm
Nice work. You'll be glad of the extra space in the tunnel for a 3" exhaust.
PostPosted: Sat Nov 17, 2012 4:54 pm
Is this engine going into a Rover? The exhaust tunnel is different to Ozy minis :wink:
PostPosted: Sat Nov 17, 2012 7:45 pm
No, goin into meeni.... Are you referring to where the gear selector hole is? As I said nothing is bolted down so when I make mounts it will go in the aus car.
PostPosted: Sat Nov 17, 2012 7:47 pm
[quote="meeni"] Will make a bolt on cap for the back of the box as well as weld some tabs to the box for bolting it to the floor, but will do that using meenis floor as this rover one is a different shape..
PostPosted: Sat Nov 17, 2012 11:41 pm
Ok sweet.
PostPosted: Thu Nov 22, 2012 7:46 pm
Got my Honda pistons and modified rods in the mail today :)
PostPosted: Thu Nov 22, 2012 7:51 pm
Whats been done to the rods Sean??
PostPosted: Thu Nov 22, 2012 7:55 pm
The top needs to have a bit taken off each side to clear the piston as they're a skinnier fit I also need to have Teflon bushes made to hold the gudeon pins in
Il send it all of when I'm having the block and crank etc machined for a polish up. Apparently the rods are pretty good from the factory though so probably won't need to touch them too much
PostPosted: Thu Nov 22, 2012 9:38 pm
I may have missed a post outlining this, but what is the expected end result spec of the engine (what are you currently targeting)?
From what I can tell its going carby NA ~125 hp, but I also know you've mucked around with blowers and stuff too which could be anywhere from 150 to 250 hp.
:D
