It is currently Fri Aug 15, 2025 11:43 pm
 Post subject: Heater Take Off Studs
PostPosted: Sat Nov 24, 2012 6:58 pm
Ok so one of the heater take off studs is cactus leading to a little leak there.
Are these easy to remove and replace? Any tricks?
They are 1/4 UNF.
Can I replace them with bolts?
Thanks guys.
Alec
PostPosted: Sat Nov 24, 2012 7:09 pm
You sure can replace them with bolts, 1/4" UNC.
You may have a bit of trouble removing the stud remnants however depending on the rust. You might be able to catch the top of the old stud with a pair of pliers or vice-grips, otherwise you will need a fine easy out.
PostPosted: Sat Nov 24, 2012 7:57 pm
These 2 studs into the head are 1/4" UNF, not UNC.
Sure, bolts are less hassle. :wink:
If you need to drill it out and retap, do it properly; use a bench drill or milling machine.... I have a 1275 head here where somebody didn't- the drill wandered and finished up into the water jacket and out the side of the head!
I fixed it by boring the head for an insert, but it wasn't easy.
PostPosted: Sat Nov 24, 2012 8:25 pm
As it happens I bought a small easy out the other weekend. ...
Thanks guys
Alec
PostPosted: Sat Nov 24, 2012 8:52 pm
If the stud is broken off be careful with that Ezy-out. They are hardened and brittle. If it breaks in there it will not be `Ezy' to get `out'. :wink:
I am a fitter/machinist by trade, and have removed many busted and corroded studs from car engines and outboard motors. No way will I use an ezy-out on small studs, they break too easy.
The correct engineering method is drill a concentric hole in the stud to the tapping size of the thread (in your case, 5.5mm) then screw a 1/4 UNF tap in. It will pick up the thread remains and they will come out with the tap. :wink: The thread should be undamaged.8)
PostPosted: Sat Nov 24, 2012 10:21 pm
The stud is there still and I should be able to get it out.
I would have left the ezy out till last but as you say the tap is the go.
Thanks for the heads up in any case.
Alec
PostPosted: Sun Nov 25, 2012 3:09 pm
I would sooner weld a nut onto the stub of a stud than I would try using an easy out.
Weld on a nut, and you've got a bolt.
And the heat from welding likely loosened it up.
You're so square
Baby I don't care
PostPosted: Sun Nov 25, 2012 3:41 pm
It's only a 1/4" stud, can't be that tight. Yep welding a nut on is fine.
A pair of vice grips will get it if there's enough sticking out to grab onto.
Warming the head up a bit helps too.
Users browsing this forum: Majestic-12 [Bot] and 353 guests
