It is currently Sat Jul 26, 2025 9:46 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 26, 2012 11:45 pm
Grinded, even both sides, can't get it out even hammered hard. Tomorrow I will drill it out maybe that works?
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
PostPosted: Thu Dec 27, 2012 8:16 am
Looks like you have hammered the remains of the rivet out and spread it to a head, grind it flush again and punch the centre of it with a 6mm PIN punch.
Or go see someone with a press...
PostPosted: Thu Dec 27, 2012 5:09 pm
Managed to drill one out and took me an hour. Broke 4 drill bits. I think it's made out of the same material of an Iron Man suit. :shock: :shock: :shock: :shock:
The original spot is slightly out of position from where I have the hole drilled. Will give myself and the drill a rest. If it doesn't fit back properly, I reckon it might be ok since the seat needs restiching anyway, so might as well change a new frame?
