Thanks guys for the input. There was a lot said about brake hoses and thanks for the link to the UK Minispares. My question was about fuel lines as
Mini Mad observed.
No
Kennomini - not cosmetic. My understanding is that CAMS require braided fuel lines (irrespective of Na Nb Nc historics etc), and I have been advised from a number of sources over a period of years that braided hoses are not RMS acceptable (NSW). Then someone, whom i cannot remember, said there is a type of braided fuel line hose that is acceptable. And then i had no idea as to whether that person's advice was correct. The logical next step is to throw it to our wider knowledge base.
Don't get me wrong, I'm not ungrateful for your combined efforts, however, I still don't see that there is a conclusive answer to the type of braided fuel hoses.
CAMS Manual of motorsport - 5th Category historics - 3.6 explains permitted use of braided hoses on brake clutch oil and fuel, and for rally cars it states:
Schedule R – Rally Cars CAMS Manual
• when flexible, these lines must have threaded, crimped or self-sealing connectors and an outer braid resistant to abrasion and flame (will not sustain combustion);
• the minimum burst pressure measured at the noted minimum operating temperature shall be:
Fuel lines
(except the connections to the injectors and the
cooling radiator on the circuit returning to the tank,
including any cooling radiator or lines):
70 bar (1000 psi) at 135°C (250°F)
Lubricating oil lines : 70 bar (1000 psi) at 232°C (450°F)
Lines containing hydraulic fluid under pressure: 280 bar (4000 psi) 232°C (450°F)
Notwithstanding the requirements detailed above, if the operating pressure of any the hydraulic system is greater than 140 bar (2000 psi), the burst pressure shall must be at least double the operating pressure.
Note: Steel ‘bundy’ tube which is designed for use in automotive applications will usually comply with the minimum burst pressure as will many flexible braided lines designed for fuel injection systems. Reputable hose and line suppliers or manufacturers will be able to provide specifications and documentation (eg, a catalogue) that can assist the scrutiny process.
The above leads me to acceptance of braided lines for competition cars.
On the RMS website you can get to the ADRs, and I have found that file 7/00 and file 17/00 seem to be the relevant documents but they are not internet accessible. I might send and email enquiry to RMS to see where it takes us. After all - its my question guys...
http://www.rta.nsw.gov.au/registration/ ... i_dl1.html and VSI 07 is as far as I could go (for those interested).
Oh and... Happy New Year to one and all!!!
..still waiting for the Italian Job sequel to see if the bus went down
