It is currently Thu Jul 31, 2025 8:59 am
 Post subject: Subframe Painting
PostPosted: Wed Jan 02, 2013 11:30 am
Hi everyone
I hope you all had a fantastic holidays.
I wanted to get some advice on painting my front and rear subframes, mostly what products peope have used and the resault after being on the road for a while.
I am going to use a few coats of etch primer, then I am tossing up using either
Septone Chassis Black
or
Septone Subframe Black
Not sure which one to go for, or if there is a better protuct to use
Any help you be much appreciated
Dave
PostPosted: Wed Jan 02, 2013 3:48 pm
I've just painted my subframes in Protec 363 automotive enamel, its badged as Autofleet. The guy at the paint supply shop confirmed what I though as being perfectly suitable for subframes and radius arms etc. He did advise against using those chassis black paints for some reason but I can't remember why. I also chose the Protec brand because because I've used it alot in the past and because they are based here in SA. How did it turn out, very glossy, perfect job. The car is far from ready for the road so I can't say how it will last. But I was assured it was the product for the job.
People told me to use 2pack but because I don't have the correct gear and I respect my neighbours I won't use it.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Wed Jan 02, 2013 4:15 pm
thanks m-jay
I will check it out.
Dave
PostPosted: Wed Jan 02, 2013 5:31 pm
VHT Roll Bar and Chassis paint seems to do the job well! $25 from Repco.
PostPosted: Wed Jan 02, 2013 6:26 pm
Online
I used Aldi gloss black enamel, it's good stuff! Brushed it on and it levels like POR15 does, no brush marks!
PostPosted: Wed Jan 02, 2013 6:43 pm
Por 15 gloss black followed by Por chassis black
The chassis black is not a gloss finish
12 months on and you can hit it with a hammer and not chip it
so far so good :D
Mark
PostPosted: Thu Jan 03, 2013 9:11 am
Thanks guys
Was looking on the POR website at the chassis black and this staitment is a little worrying
WARNING: THIS PRODUCT CONTAINS CHEMICALS KNOWN TO THE STATE OF CALIFORNIA TO CAUSE CANCER, BIRTH DEFECTS OR OTHER REPRODUCTIVE HARM.
Dave
PostPosted: Thu Jan 03, 2013 10:07 am
Pretty much any solvent, strong cleaning agent, lubricant etc that you use on cars or even around the house is a potential carcinogen. It is entirely up to the user to educate themselves and take adequate safety precautions. These days the safety data sheet of most products can be found on the manufacturers website and you should find it and read it.
With the new workplace health and safety laws many workplaces won't allow a chemical on-site without a current SDS.
The safety data sheet for POR chassis coat is here:
http://ppcco.com.au/fact_sheets/msds/msds_chassiscoat.pdf
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Jan 03, 2013 6:09 pm
Dabid wrote:
Thanks guys
So if you don't live in California it won't hurt you. :lol:
PostPosted: Fri Jan 04, 2013 9:24 am
I like your thinking peterb :D
Dave
PostPosted: Fri Jan 04, 2013 9:42 am
Read about used engine oil.....that is none to good for you either! :wink:
PostPosted: Thu Jan 10, 2013 9:06 am
Has anyone used KBS-Coatings?
http://www.kbs-coatings.com.au/kbs-chassis-coater-kit
looks to be quite good. i might give them a go.
Dave
PostPosted: Thu Jan 10, 2013 9:15 am
Online
IMO just about any metal suitable paint will do, we don't salt the roads here, so subframes don't die from corrosion in 5 years like in the UK.
If you keep mud off them you can still see the `Mowog' stencilled on originals 40 or 50 years ago.
PostPosted: Thu Jan 10, 2013 10:19 am
Thanks DrMini
Dave
PostPosted: Thu Jan 10, 2013 6:06 pm
The nasty solvent in the chassis products is xylene (http://en.wikipedia.org/wiki/Xylene). Not all that nasty unless you drink the stuff or huff the vapours.
California is paranoid about any volatile hydrocarbon... :?
cheers,
Jacob
Users browsing this forum: drmini in aust and 101 guests
