mini_mad_matt wrote:
Camira-
won't fit in 10" wheels
need spacers,
use drum brake CVs & drive flanges (not the strongest setup for big torque output),
need caliper mount welded onto the cast iron swivel hub (unsafe, IMO),
need engineering.
My sports sedan has holden/camira brakes but uses a different setup to what you describe.
Uses disc cv's, modified morris 1500 flange and has a rather simple bracket to mount the caliper to the hub.
Obviously it uses big wheels so i have no idea what the spacing would be like on a road car.
Wouldn't really suggest this setup for a road car
My opinion on the original question is go with the 7.5 or 8.4 mini brakes depending on what wheels you want. Keep it nice and simple, no engineering certificates etc, easy to find parts and they work just fine. I don't think boosters are necessary, but that's a personal opinion as i prefer a pedal that needs some force rather than a soft one. Either way, go out and practice some emergency braking to realise the full potential or the brake pedal.
I have seen a couple of Camira setups here in Sydney on road cars (one car is from tassie), both have the steel caliper mount arc welded to the swivel hub.
This wrong on a couple of counts:
1. welding of suspension components in Oz is illegal except by the vehicle manufacturer.
2. The swivel hub is NOT steel, it is cast iron. I know this because I have machined a few. A highly stressed cast iron suspension component like this should never be welded like this, it is prone to cracking.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
