It is currently Tue Jul 22, 2025 6:50 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 01, 2013 5:21 pm
Mini Mad wrote:
My favourite oil is:
1. Brad Penn Grade #1 "The Green Oil"
Contains high levels of ZDDP for our tractor flat tappet cam engines:
In addition to our unique base oil cut, increased concentration of “zinc” (zinc dialkyldithiophosphate a.k.a. ZDDP) provides outstanding anti-wear/anti-scuffing protection for engines employing either ‘flat tappet’ or roller cams. BRAD PENN® Penn Grade 1® High Performance Oils have been evaluated by a number of premiere camshaft manufacturers with tremendous success. Many are now recommending our Penn Grade 1® High Performance Oils to provide outstanding protection for their ‘flat tappet’ or roller cams.
http://www.penngrade1.com/
Second choice would be Castrol EDGE Sport 20w50.
I have used both these oils and am very happy with both, I am currently using BRAD PENN in the group Nb car as recommended by GR (which he uses in his race car) which is a good enough reason for me, looks a little unusual however to see green engine oil in a mini.
PostPosted: Sat Feb 02, 2013 9:00 am
Not that easy to find XLD Classic?
I can only find XLD Premium?
What's the difference?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Feb 02, 2013 9:06 am
Classic being an SG oil should have more ZDDP in it then the Premium, which is an SJ grade.
There is a blurb on the Valvoline site somewhere besides this..
http://www.valvoline.com.au/files/productpdfs/8.pdf
Good discussion on ZDDP in this thread, scroll down..
http://forums.pelicanparts.com/new-zeal ... 1-oil.html
