It is currently Mon Aug 11, 2025 12:16 am
PostPosted: Mon Feb 11, 2013 7:25 pm
I have a cast inlet manifold which has been cut off the exhaust outlet and have found a small hole in the area which was cut.
Can I mig weld up the hole or will I stuff up the manifold by blowing a bigger hole into it?
Is areldite maybe an option?
Car has been running OK but I am assuming will go better without th hole :roll:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Feb 11, 2013 7:28 pm
we used to braze them up no problemo
PostPosted: Mon Feb 11, 2013 7:30 pm
Sadly I have sent my gas bottles back due to rental cost :cry:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Feb 11, 2013 7:46 pm
Have gas, can braze... :wink:
I now use oxy + LPG, that saves me 1/2 the BOC exorbitant rental.
PostPosted: Mon Feb 11, 2013 7:49 pm
I stuffed one up that I cut years ago and put a hacksaw slit in the wrong spot. I filled it with Selleys Knead it. It lasted for years.
Devcon would do it too.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Feb 12, 2013 5:42 am
Yeah i used Devcon .. sets rock hard just make sure you kneed it into the hole to plug it ...
Could be braze welded , not MIGED , Maybe ARCed if you had the right rods but even then its touch and go ..
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Tue Feb 12, 2013 5:45 am
JB Weld would work OK too, do you have it over there?
Al
PostPosted: Tue Feb 12, 2013 9:51 am
You can get it online, but I've never seen it in shops.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Tue Feb 12, 2013 10:10 am
Thanks Guys.
I have some Sellys kneed it so I might give that a try.
I thought about solder but it may have too low a melting point as it is close to the exhaust.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Feb 12, 2013 2:35 pm
If the metal isn't too thin you could tap the hole and screw in a bolt or grub screw.
PostPosted: Tue Feb 12, 2013 2:54 pm
Having cut lots of these manifolds over the years, if there's a hole there it'll be thin as tissue paper.
Bring it over Michael if the glue doesn't work, and I can braze it properly, no problem.
PostPosted: Tue Feb 12, 2013 3:33 pm
Thanks Kevin,
I will have another look at it tonight and make a decision which could involve a drive out west :wink:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Feb 12, 2013 4:18 pm
JB Weld or Devcon will work. JB can be got from most hardware stores.
Users browsing this forum: fuzzy-hair-man and 156 guests
