It is currently Mon Jul 21, 2025 10:04 am
Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon Feb 04, 2013 10:05 pm
Rocker quality has always been shakey. It's difficult to have quality control when more than one manufacturer is involved. If you call a company in china or even the uk, get a quote for manufacturing, there's nothing stopping them from outsourcing manufacturing!
PostPosted: Sun Feb 17, 2013 3:10 pm
Another crook part today- new Pot Joint bought locally.
I bought 2. Both new in sealed plastic packaging.
One was incorrectly ground/machined on the outer diameter that goes through the side cover bush.
The diameter should be 1.250", on this one it varies from 1.249 to 1.254 when measured accurately with a micrometer. It is .005" tapered, and .005" oval too... :evil: Made it impossible to machine the side cover + bush to fit it properly, so the new bush is now buggered too. :x
Pot joint can go back for exchange tomorrow and I'll measure its replacement in store. [edit] its replacement was OK.
Its mate was OK, it just goes to show how good QC from overseas isn't these days. :cry: :cry:
PostPosted: Fri Feb 22, 2013 3:32 pm
or how they think they are so clever sending all their B Graded stuff thousands of miles away where customers are unlikely to come back and thump the desk in their shop :!: :shock: :lol:
PostPosted: Fri Feb 22, 2013 5:36 pm
.... but sometimes they get a very rude surprise...... javascript:emoticon(':twisted:')
Cheers, Ian
PostPosted: Fri Feb 22, 2013 6:13 pm
Another unfinished part from the northern hemisphere then sold here.....
Thermostat housing.
MOWOG originals had the 3 stud holes drilled to 8.5mm, not these ones..!
They are diecast alloy, unmachined, and the 3 holes are tapered, 9mm+ at the bottom & just under 8mm at the top, and so they jam on the 5/16 studs easy. Hard to get it back off.
I drilled the buggers out to 8.5mm, but why should we need to... :twisted:
PostPosted: Sat Feb 23, 2013 2:19 pm
How about 2 brand new layshafts, both of them are bent
PostPosted: Sat Feb 23, 2013 2:40 pm
This thread is depressing me :cry:
PostPosted: Sat Feb 23, 2013 2:41 pm
You are not alone...
I now usually get mine from Heritage MG parts, they make them here from real NiCr steel and properly heat treat & grind them.
PostPosted: Sat Feb 23, 2013 3:06 pm
Thanks for the website Doc , quite good prices too http://www.mgspareparts.com.au/
PostPosted: Sat Feb 23, 2013 3:23 pm
The Mini King
Mini King Aust Have them Made in Aust from similar metal as cooper S crankshaft
and heat treated
PostPosted: Sat Feb 23, 2013 4:55 pm
and heat treated
Thanks John, I didn't know this. :wink:
It is a constant worry when buying this sort of stuff in from overseas now, the suppliers seem to outsource to best price and don't give a rat's about the Quality. Or, check their goods are made right when they get them.
I'm sure most of us on here would pay a bit more, IF the quality was there.
PostPosted: Sat Feb 23, 2013 6:09 pm
The Mini King
and heat treated
I should also add that the diff pins we supply are made in a siimilar way
I am consantly trying to make sure that I supply parts of the higest quality possible
But I must say not everyone understands that quality often costs a little more
There are some parts that I just do not supply because of quality problems
PostPosted: Sat Feb 23, 2013 8:38 pm
John Smidt wrote:
and heat treated
Do you have a website or catalogue john ?
PostPosted: Sat Feb 23, 2013 9:42 pm
I bought a comp layshaft from one of the Mini Spares suppliers in the UK. It was bent and took several emails and six months to get a replacement. Yes, six months!!!!
I certainly would pay more for quality especially when it comes to safety like ball joints. ;)
PostPosted: Sun Feb 24, 2013 9:49 am
yep we have 2x Leyshafts here, brand new & both bent
