It is currently Thu Jul 10, 2025 8:12 am
PostPosted: Sun Mar 03, 2013 7:40 pm
Does anybody know if it's possible to purchase the early type of clutch release bearing that had a flat thrust face that mated up with the clutch contact plate.
My regular suppliers just carry the bearing that contacts around the circumference of the outer bearing shell and I find that these don't last very long when used with a competition pressure plate. :cry:
Curly
PostPosted: Sun Mar 03, 2013 7:42 pm
I happened across a few NOS a while ago - and have some left. $80 posted
PostPosted: Sun Mar 03, 2013 7:51 pm
PM sent
Dave K.
PostPosted: Sun Mar 03, 2013 7:55 pm
Fantastic - PM sent
Curly
PostPosted: Mon Mar 04, 2013 7:51 am
These are just timkin thrust bearings are they not?
http://www.minisport.com.au/prod814.htm
Lillee - 1969 Morris Mini K
PostPosted: Mon Mar 04, 2013 8:04 am
yes,,, just that they`re getting particularly hard to get these days
PostPosted: Mon Mar 04, 2013 8:38 am
I see...
PostPosted: Mon Mar 04, 2013 9:08 am
Lillee wrote:
I see...
note that the mini sport page says "N/A NO ETA"...
PostPosted: Mon Mar 04, 2013 10:12 am
simon k wrote:
Lillee wrote:
I see...
Yeah I realised that after Matt's post
PostPosted: Mon Mar 04, 2013 2:07 pm
Yes I found out the new ones start to wear a groove in the surface of the mating plate :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 04, 2013 2:52 pm
That's because the mating plates are now soft. They used to be harder.
Some of the race guys swap their old plates in when they buy a new diaphragm, or put the new spring into their old diaphragm cover.
PostPosted: Mon Mar 04, 2013 2:56 pm
yeah, I had that too - I surface ground the plate a couple of times over the life of a couple of the standard bearings, then replaced it with the flat faced type and it's perfect
they'll also survive running off-centre if your wok is worn through the hole making the thrust carrier crooked when you push on the clutch pedal. Standard ones don't like that...
like Curly said, if you need a clutch that can handle more than standard torque levels, the crappy thrust bearings available now can't handle it
PostPosted: Mon Mar 04, 2013 3:03 pm
The original flat faced bearing was used with the coil spring clutches eg 850, 997 Cooper and 1071S.
Then they brought out the `new' (POS) one when they introduced diaphragm spring clutches.
Why did they `fix' it, when it wasn't broke... :cry:
Old (good) flat one is obsolete because it was `replaced' 50 years ago.
