It is currently Mon Jul 21, 2025 9:21 am
Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Sun Feb 24, 2013 12:47 pm
Maybe they have heard that QLDers like things bent?? Bananas etc
PostPosted: Sun Feb 24, 2013 8:45 pm
The Mini King
MiniBill wrote:
John Smidt wrote:
John Smidt wrote:
Mini King Aust Have them Made in Aust from similar metal as cooper S crankshaft
and heat treated
Thanks John, I didn't know this. :wink:
It is a constant worry when buying this sort of stuff in from overseas now, the suppliers seem to outsource to best price and don't give a rat's about the Quality. Or, check their goods are made right when they get them.
I'm sure most of us on here would pay a bit more, IF the quality was there.
I should also add that the diff pins we supply are made in a siimilar way
I am consantly trying to make sure that I supply parts of the higest quality possible
But I must say not everyone understands that quality often costs a little more
There are some parts that I just do not supply because of quality problems
Do you have a website or catalogue john ?
I am behind the times with My website, I have ben trying to build this myself but I did not
get it Done, However with some outside help good news is around The corner
I have sold Out of the Catalogues, We are now trying reprint them
PostPosted: Sun Feb 24, 2013 9:21 pm
John whilst you have always been extremely helpful whenever I have rung a website will bring you untold new business. I often do my mini shopping of an evening when all the shops are closed.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Feb 24, 2013 9:45 pm
Thanks John
PostPosted: Mon Feb 25, 2013 7:58 pm
A member on here just got a new set of 1.5:1 Mini****** roller tip rockers from UK this week.
6 of the 8 adjusters were bent (like my recent forged/cast ones were) and the nuts all loose as buggery on the threads (ditto).
I gave him a set of s/h A+ adjusters and nuts, all seems good now.
Talk about spoiling their ship for a pennyworth of tar... these things are not that cheap! (but they should be, seeing as where they are made now).:twisted:
PostPosted: Wed Mar 06, 2013 1:51 pm
Bought 8 new long brass nuts for the exhaust manifold.
All 8 needed a tap put through them so they would screw on with fingers.
And this was after I chased all the stud threads with a dienut. :x
It's a good thing I'm a machinist... :roll:
PostPosted: Sat Mar 09, 2013 2:36 pm
Yeah...otherwise you'd be screwed :roll:
PostPosted: Sat Mar 09, 2013 3:49 pm
I tend to regret it every time I fail to do this when putting twins on with tight extractors.
 Post subject: another too add
PostPosted: Sun Mar 24, 2013 10:02 am
add the new not made made in china cv joints to the list also
tested 2 that were bought in australia and they are too long in the shaft so the drive flanges wont locate properly,the rest will be going back to the supplier
:twisted: :twisted:
PostPosted: Sun Mar 24, 2013 12:06 pm
Not ony car parts I'm afraid.
Won a 1Kg bag of mini easter eggs in a raffle last week. Wow! I thought, how good is this.
But they tasted like dog-sh!t
Looked at the label on the bag. You guessed it - Made In China
FFS :x
PostPosted: Sun Mar 24, 2013 12:17 pm
FFS :x
Rofl , best to stick to Genuine Caburys " from a reputable dealer " :-).
PostPosted: Sun Mar 24, 2013 12:34 pm
can't beat australian made chocolate :) try Heritage made in melbourne can buy straight from factory :D :D
65 panel van Sprog
73 panel van Iggy
PostPosted: Sun Mar 24, 2013 7:42 pm
Nutz included?? :)
or Whittakers from Nu Zuuland...great stuff :D
PostPosted: Mon Mar 25, 2013 10:47 am
I love their peanut slabs " damn addictive
PostPosted: Fri Apr 18, 2014 8:32 pm
Thread revival.
With my large box full of small parts I started putting bits onto the 850 today. I thought I would start with the doors. First parts on are the rubber drain tubes from the window slider area down to the bottom of the doors. I had bought a brand new set from the UK.
They are cut to length and one end is swaged out to a larger diameter so I though they would fit... Wrong... The bottom end is meant to slide inside a steel tube but they are way too large to go in. I had to use the belt sander on them to make them fit.
That wasn't too bad, just dusty and time consuming.
Then I went to put the handles together and found that the inside handle that is meant to clamp onto the 1/4 inch square rod that goes from the outside handle to the latch mechanism is way too big. It has a screw in it that is meant to allow it to be tightened over the square rod but there is no way that little screw is closing a gap that big. So the new handles are going to float around and rattle. Great. :roll:
I expect I am about to have a fight with my Newton Commercial door trims from what I have read over the last few weeks on here.
Why is it so hard to use new parts??
M
