It is currently Thu Jul 24, 2025 2:14 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 05, 2005 9:39 am
skssgn wrote:
were they custom drilled or what! I wouldn't mind seeing 15"s on a moke, I've seen 14"s...
i have seen 15x7 superlites on a moke :D our local jax tryes is building one at the moment .
lookin for another clubby
PostPosted: Thu May 05, 2005 4:12 pm
bnicho wrote:
4 x 4 inch PCD (101.6mm). Shared with Hillman Imp, Holden Torana 4cyl, Vauxhaul Viva, Morris Minors.
Whatever you do, DO NOT use 4 x 100mm wheels (Gemini, Mitsubishi, Honda, Toyota), even if they physically fit!
thanks very much 8)
PostPosted: Thu May 05, 2005 5:01 pm
but they do look good :wink:
PostPosted: Thu May 05, 2005 6:08 pm
Not that I'm disagreeing with what you're saying, but could you explain your comment a bit more? Couldn't the 4x100 but altered so they are suitable?
PostPosted: Thu May 05, 2005 8:22 pm
Problem with running 4x100 pattern is it bends the wheel studs. Which then break... :shock:
It is possible to drill the wheel bigger at 4x4" and fit steel inserts, depending on the wheel geometry, of course.
PostPosted: Thu May 05, 2005 8:54 pm
These are 15x6.5 on one of my customers mokes
you can really "FEEL" the size & weight of em tho
not for me thankyou very much.
PostPosted: Thu May 05, 2005 10:21 pm
Would you be able to fit these to a Mini? (can't see why you can't) They are available as a 14x6 size blank that can be custom-drilled...
http://www.speedywheels.com.au/images/zoom/sirocco.htm
