It is currently Mon Jul 21, 2025 6:33 am
 Post subject: wind up doors on an 850
PostPosted: Mon Mar 25, 2013 4:25 pm
Will wind up window doors from a deluxe fit in a 850 shell?
Can't recall if I read the locks & B pillar were different, or is that only for a clubby
PostPosted: Mon Mar 25, 2013 4:52 pm
It'll fit, won't be perfect but will work.
PostPosted: Mon Mar 25, 2013 5:03 pm
swap over the nylon buffer with the metal cup,
or vice versa
PostPosted: Mon Mar 25, 2013 5:25 pm
Use windup & later door rubbers (wider) not the 850 ones.
PostPosted: Mon Mar 25, 2013 6:00 pm
The Mini King
On the 850 the nylon is on the door and the metal cup is on the Body, On the deluxe the metal cup is on the door and the nylon is on The body, Take note The cups and the nylon
on the deluxe are larger than the ones fitted to the 850
If You have a good set of sliding window doors do not throw them out
PostPosted: Mon Mar 25, 2013 6:12 pm
Or do throw them out, just let us know where you dump them!
Users browsing this forum: No registered users and 114 guests
