It is currently Mon Jul 21, 2025 3:18 am
PostPosted: Thu Mar 28, 2013 3:20 pm
Just about to order a pair of front floors to repair a 65 mini van (Winding windows). The van is not here, so can't check, but should it have a floor with the hydro pipe tunnel, or the earlier style floor?
Chris
I can only please one person per day,
Today is not your day,
Tomorrow is not looking good either.
PostPosted: Thu Mar 28, 2013 3:34 pm
Early if a 65. Hydro style floors came in `67.
Oz vans had a sedan floor with an extension bit on the back, there was a thread about it here a while back.
And I think Watto mentioned it in TME mag.
PostPosted: Thu Mar 28, 2013 7:28 pm
UK vans and estates also had a sedan floor with an extension at the back, but did Australian vans use a hydrolastic floor despite not having hydro suspension?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Mar 28, 2013 7:36 pm
From 1967 on, every Mini here got the `hydro' floor whether it had hydro, or not. This was the Australian made floor. Our `77 van has it.
PostPosted: Thu Mar 28, 2013 7:40 pm
Interesting, I guess it wasn't worth pressing the plain floors as well.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Thu Mar 28, 2013 8:28 pm
A floor press forming tool (die) is a big expensive bit of tooling. I think up until 1967 they used imported floors, although many other panels were being produced here by then.
PostPosted: Fri Mar 29, 2013 6:59 am
Which would explain why they never went back to the original die once they reverted to rubber cone.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Fri Mar 29, 2013 7:29 am
Hmmm are we sure cause the still ran pudding stirrers until clubman era also had the push starter button pressing
PostPosted: Fri Mar 29, 2013 7:30 am
PostPosted: Fri Mar 29, 2013 7:47 am
The starter button bump was included in the Oz 1967 floor pressing, all Minis here had it until production stopped in 1978. Whether puddin stirrer, remote or rodchange.
UK cars from Mk3? (when rodchange started) all had a different floor, the tunnel was flat on top and had no starter button bump.
When we went to rodchange here, they just did minor mods to the hydro floor die to accommodate the rodchange shifter mounts. A bit of a bump and 2 more holes.
PostPosted: Fri Mar 29, 2013 9:12 am
The Mini King
The section that housed the hydro lines is used for the Brake lines Battery cable, Fuel line and on some models the vapour tube , This gives more protection to all these parts than they had on the early floors
PostPosted: Fri Mar 29, 2013 11:25 am
The two Mini K vans I have owned have had English floors. Maybe both had been changed before, but they both looked factory.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Mar 30, 2013 9:17 am
Bugger should have checked back here sooner,
I went down thursday and got the pans before checking back here, got some hydro front halves (as I was told it should be) and you were all right, need the non hydro ones.
Bright side, see what followed me home yesterday. Last rego was 1987
PostPosted: Sat Mar 30, 2013 9:23 am
That's a really nice find. Rat Grey for a van, is there any other colour?
