It is currently Sat Jul 19, 2025 11:51 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Mar 29, 2013 2:00 pm
That came out looking really good , well done.
PostPosted: Wed Apr 03, 2013 5:25 pm
Haze Blue 850,
The pics you posted show a non standard air hose inlet. The original type only projects about an inch or so. Early ones had a metal inlet fittting and later ones had a plastic fitting. Somebody has modified the air inlet and made it a larger diameter and longer. Probably to get more air into the car.
Its also worth noting that later model Morris Minors used a similar heater assembly but they didn't have the side covers over the demister hoses. The one I saw in NZ was a 60/61 Minor van with a 1098 engine and the same Smiths heater under the dash.
Hope this helps
RonR
68 build Mk1 Cooper S
PostPosted: Wed Apr 03, 2013 6:34 pm
Thanks RonR
That intake could be oversize. It's 4&1/4. With the hose over it it will look OK. It looks like the original piece? Who knows where the PO got it.! :-)
Alex
PS Painted the car on the weekend. Will start a Members Cars blog soon.!
Years of prep are coming together. I,m starting to see results.!!
PostPosted: Fri Apr 05, 2013 7:34 am
http://www.ebay.co.uk/itm/Mini-Mk1-2-Fr ... 20d0cb95d5
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
