It is currently Thu Jul 24, 2025 5:54 am
PostPosted: Thu Apr 04, 2013 9:53 pm
John Smidt wrote:
@lmbm,
Geez, those hardness numbers of yours seem low!:shock: Have you calibrated the machine lately?
I tested a Karcraft comp one and a Heritage MG 4 synchro one last year, both were between 61-63HRC.
Doc If I send You one of My Layshafts and a Diff pin could You do a hardness test on them for Me Please
No problem John. I have access to two Rockwell testers in different places. :wink:
PostPosted: Fri Apr 05, 2013 7:02 am
The Mini King
Thank You very Much Kev, I will get them to You
PostPosted: Fri Apr 05, 2013 12:28 pm
Mods rock!
lmbm wrote:
Once i managed to do to some hardness tests on few layshafts, below the results,
i'd say you will be fine with a good second hand A+ layshaft, they seldom wear.
- new pre A+ Australian MG Heritage layshaft 43 HRC ( sourced in 2008 )
- new Minispares A+ competition layshaft 43 HRC ( sourced in 2008 )
- used factory A+ layshaft from low milleage metro 51 HRC
- used factory layshaft from high milleage 4 synchro remote box 52 HRC
- new old stock pre A+ 4 synchro layshaft 55HRC
Luis
That's close to what I got too, however surface hardness is one thing but if the hardness layer is only a shell ie no depth, then then it won't matter how hard the surface is, the shaft will fail, ruining everything that runs on it. I gave up a while ago trying to find decent layshafts.
PostPosted: Sat Apr 06, 2013 3:28 pm
The Mini King
MattE wrote:
Bit of an update:
KC don't have stock of A+ ones for up to a week. If they did have stock, it wouldn't be the same material as their pre A+ ones.
Heritage MG and Mini King don't have the A+ ones either.
I've ordered a hardened EN36 one from MED in UK on Graham Russell's advice - thanks for your time on the phone Graham. A reasonable 46UKP.
Thanks again for the help.
Matt
Mini King are waiting for next batch of Aust Made EN36 stepped Layshafts
We do have EN36 4speed Sync layshafts in stock
Users browsing this forum: No registered users and 114 guests
