It is currently Tue Jul 22, 2025 8:31 am
PostPosted: Fri Apr 05, 2013 10:36 am
Hi guys,
So finally got home to the mini after working 3 weeks straight. :x
need some help identifying the compliance plate because I can't read it properly but best I can see it says:
YMA2S2
30910
9YA75A/V17
32039
1/SNOW WHITE/1
on top of the radiator shroud (30364):
and a pic of the bogged up beast:
Thanks guys
PostPosted: Fri Apr 05, 2013 11:22 am
Hey Minirock.
YMA2S2 is a Morris Mini Deluxe body and 9YA ..... is a 998cc, as for the year ....... i dont know but some here will be able to narrow it down
Edit after a bit of a search snow white paint says 1967
Cheers bill
PostPosted: Fri Apr 05, 2013 11:44 am
There should be a body number near the compliance plate as well that matches the compliance plate.
Just noticed the front panel looks to be the same as Cooper S.
Diagonal brace and section to mount oil cooler, may have had some front panels replaced.
Cheers Rob
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Fri Apr 05, 2013 12:35 pm
the numbers on that plate look perfectly legit - the car number on the ID plate should be about 500 higher than the body number on the radiator shroud, which it is (546 is close enough - body may have been forgotten in a corner for a little while before going on the production line)
Cheers Rob
definitely only replaced, don't go thinking it's an S because of those panels!
PostPosted: Fri Apr 05, 2013 2:23 pm
awesome thanks for that guys, at least I have a good idea of the body although it has got a clubby interior and a 1100cc engine in it
not sure if it's an A series though
just defiantly a bitsa
PostPosted: Fri Apr 05, 2013 2:35 pm
Yep it's a 1098 from a Leyland Mini. A series... we never got A+ here, except in a few very late Mokes.
PostPosted: Fri Apr 05, 2013 5:39 pm
thanks for all your help guys
Users browsing this forum: bharp831 and 96 guests
