It is currently Tue Aug 12, 2025 6:44 pm
PostPosted: Sun Apr 07, 2013 11:20 am
Has anyone got some pictures of a reinforced front subframe as David Vizard says it should be done :?:
I'm looking at doing this myself, the tie rod area and seam welding is easy. What I'm not clear on is the reinforcing plates that go on the rear floor pan mount sections and if their needs to be anymore in other areas.
PostPosted: Mon Apr 08, 2013 6:15 am
There was some discussion on this sometime ago -Madmatt is the bloke to talk to
David L
PostPosted: Mon Apr 08, 2013 7:58 am
when you`re down here next Kenno i can show you all the ins & outs of frames strengthen-ings easy-peasy
PostPosted: Mon Apr 08, 2013 5:25 pm
Just about to weld up my subframes for the Monte replica gravel rally car - so any tips or sketches I can start with Matt????
EDIT: found this on a UK forum -
http://forum.minicooper.org/showthread.php?t=11955
Dave K.
PostPosted: Sun Apr 14, 2013 7:17 pm
The blue parts are what I did to my frame, the suspension towers were welded;
The front tie rod ears, 3mm plate;
Bump stop mounts 2mm plate;
Rear firewall mounts 2mm plates (on the bottom of the frame & still need to drill the holes through) in Vizards book he doesn't explain how large the plates have to be... :? ;
Users browsing this forum: Bing [Bot] and 256 guests
