It is currently Fri Aug 08, 2025 2:31 am
PostPosted: Tue Apr 09, 2013 2:58 pm
Hi guys I'm just wondering about putting a 1975 leyland mini 1100 engine in to a 1962 Morris 850 would I have any issues or need to change anything? With a 1.44 diff ratio in it also? If that makes any difference.
Thanks in advance =)
Regards Kermit (TadPole)
PostPosted: Tue Apr 09, 2013 3:03 pm
Fitment wise, the only issue you'd have is that it's rod change gearbox and your 850 will have a pudding stirrer gearlever which means cutting large holes in the floor *shudder* so your gear lever comes out of the floor, as well as holes for rod change brackets.
Your speedo and odo will read wrong too but that can be recalibrated.
If you buy the engine, make sure you get a receipt stating the engine number for rego purposes.
Lillee - 1969 Morris Mini K
PostPosted: Tue Apr 09, 2013 3:22 pm
1975 engine should be a rod-change type gearbox with "pot-type" axles & 998cc type donk (engine)
your 850 should be a puddin stirrer gearshift with uni-joint type axles
so they can be interchanged with a bit of work
however if your 1975 Leyland actually has an 1100cc engine in it then i`d be checking what gearbox it has first
nearly all these cars have been played with at some stage & it`s anyones guess what engines & gearboxes are actually in your cars till we see them,,, maybe take some pics of undewr the car for both the gearshift mechanisms & the axles where they come out of the diff housing yeah??? then we can tell you for sure
PostPosted: Tue Apr 09, 2013 3:30 pm
Oh yeah forgot drive shafts! Thanks Matt
PostPosted: Tue Apr 09, 2013 3:33 pm
just on that point, it's a 3.44 - the car couldn't drive with a 1.44 ;)
PostPosted: Tue Apr 09, 2013 4:24 pm
That could be a severely dyslexic 4:11 :!:
PostPosted: Tue Apr 09, 2013 6:07 pm
Kermit's car once had a remote box in it and already has the hole in the floor.
If you get the driveshafts and shifter mechanism with the engine, then no problem. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Apr 09, 2013 6:10 pm
Simple question Simon...did 850s have the lowest of all Mini Diffs? or does a Moke claim that one?
I would expect they would given their limited amount of go-forward (I know, Issy had to detune them because they were "too fast" in their day)
PostPosted: Tue Apr 09, 2013 6:26 pm
Lowest diff was fitted to mokes (& Morris 1100) at 4.267:1
Stock 850 was 3.76:1
cheers,
Jacob
PostPosted: Tue Apr 09, 2013 7:03 pm
nah the later mokes had a 4.3 :-)
edit--> 15/65
PostPosted: Tue Apr 09, 2013 7:39 pm
I read in one of the UK Mini mags that the 998 Cooper coil be special ordered with a 4.9. Popular with ice racing in Scandinavian countries.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Apr 09, 2013 7:55 pm
Dang, ok my figures stand for pre-1975 Oz producton then? :lol:
cheers,
Jacob
PostPosted: Tue Apr 09, 2013 7:58 pm
It's a 998 block with an 1100 crank. Bit of work done. It doesn't have the gear stick and rod changer. Would I be able to get one? I could be wrong but I'm quoting what I was told.
Yeah as bnicho said its already had the holes cut for it as it had one in it befor.
PostPosted: Wed Apr 10, 2013 7:34 am
The engine I'm looking at getting was in an accident that the car rolled a few times and destroyed the gear selector but the box itself is intact and so is the engine. Still holding oil etc. should I be checking anything or be concerned about the engine needing work or having issues that you can't see. It may very well be perfectly fine but because its at the top of Australia and I'm in Melbourne I can't go and look at it myself.
PostPosted: Wed Apr 10, 2013 7:49 am
Thats a difficult question because none of us can look inside the engine to check it
so you just have to "suck-it-n-see" as the saying goes :-)
& yes the shifters are easy enough to get, try josh from Minimports maybe
