Hey guys, Long time no post!
Im doing up another Leyland , this time is an 'S' so slight upgrade
It had badly rusted out hinge areas on the doors and the usual A panel rust areas, So I welded them up, on the door areas around the hinges I badly warped the area around them and after taking out as much as I could, I still put a moderate amount of bog on them to keep the lines nice. My A panels also have a considerable amount of bog. I think only one area that has more than 3mm is the lower drivers side A panel hinge holes.....
How will the hinges hold up on these bogged areas? How tight do you do your hinges? Do big washers on the inside of the door skin help dissipate the pressure and reduce risk of cracking?
Ive done up a few cars and some have never had problem with heaps of bog on areas that you bolt things on, But I'm afraid this might be too much...oh well too late now.
Cheers guys
