It is currently Sun Jul 20, 2025 3:49 pm
 Post subject: Running like a..
PostPosted: Sat Jun 01, 2013 9:11 pm
Ok so the car is running a bit rough. I initially thought it started emitting a fair bit of smoke but I reckon it is steam. It almost got to the redline on the temp gauge today.
So am I right in asuming it is a head gasket or something like that leting water over to the cylinder?
I am due a visit to Murrarie so will probably get it sorted when the budget will allow.
Hope you are all having a good weekend.
Alec
PostPosted: Sun Jun 02, 2013 12:01 am
Check your radiator and oil caps to see it their is evidence or either water or oil where it's not ment to be.
PostPosted: Sun Jun 02, 2013 7:20 am
I checked the rad to see if it was bad and there is a bit of muck in there. Didnt think to check the oil cap so will do.
Thanks Kenonmini.
Alec
PostPosted: Sun Jun 02, 2013 2:44 pm
Yeah a tiny bit of white slime. I had the rad cap off and it was steaming a bit out the exhaust but as soon as I put the cap on I guess the pressure pushed more through because the steam went up tenfold almost immediately.
More things to fix...
Alec
Users browsing this forum: Bing [Bot], fuzzy-hair-man and 77 guests
