It is currently Sun Aug 17, 2025 7:48 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: BMW twincam conversion
PostPosted: Fri Jun 21, 2013 8:51 pm
This thread is to help me figure out all the little things that I get confused with during my twinki build.
To start with I'm building a 1360 (1100S), 8 valve (K100), fuel injected, naturally aspirated (single TB), four syncro remote box, quafie ATB diff, pot joint CV's and that's about it so far.
The first issue I want to figure out is the block details (#12YDTaH). This is what I have;
In the 3rd pic you can see at the back of the block behind cyl 4, what is that threaded hole :?:
In the 4th pic what is the threaded hole in the middle of the block :?:
And what is the threaded hole near the edge of the clutch end in the middle :?:
Also in the 4th pic what are all the round sections between the pushrod channels :?: do they lead to oil galleries, can these be drilled and taped into for oil drains :?:
Finally can the dizzy hole be sealed with a welsh plug, what size :?:
PostPosted: Fri Jun 21, 2013 9:53 pm
Q1 It's in the oil pickup, there is a brass plug goes in there to seal.
Q2. It's unused on transverse engines, it may be used on a Midget for something like air filter support (maybe).
Q3. Water jacket drain, takes another brass plug.
Q4. Oil drain gallery from rocker gear. Not sure how thick the metal is but could be (carefully) tapped.
Q5. Maybe. Or contact Benjamin on here, he sells a pretty CNC alloy cover for it.
PostPosted: Fri Jun 21, 2013 10:26 pm
Q2. I've been told that was used on the assembly line to hold the block and position for machining. Could be wrong though.
Q5. Yea you can use a plug, just measure the hole and buy a plug and knock it in.
PostPosted: Sat Jun 22, 2013 4:24 pm
Made from 6061 billet, CNC machined to fit A-series engines.
Price is $40 each Machined Finish, includes new o-ring and stainless cap screw.
PostPosted: Sun Jun 23, 2013 5:58 pm
sealed up most of the block deck today, just need to track down some castiron for the two end head studs.
Also degreased and pressure washed the block, three different coats of paint so far plus the factory paint.
It's good to be finally physically doing some work on this build, it's been in the pipe line for a couple of years now gathering parts and finalizing specs.
PostPosted: Sun Jun 23, 2013 9:26 pm
Hi Kenno
I'm sure you will find a lot of your answers here :)
A couple of tips at this stage, DON'T let the machine shop take too much metal off the deck, or the head, particularly if you are welding up the oil returns in the alloy head
http://www.ausmini.com/forums/viewtopic.php?t=77313
Dalmeny
PostPosted: Mon Jun 24, 2013 7:23 pm
Yeah I've been watching your build thread.
My efforts to find some cast iron rod for the end stud holes hasn't worked out so I looked around the yard and came up with an old cast iron cinema seat frame so my guess is seeing as it's decades old and things were built to last back then it'd be half decent quality steel.
So I began to cut it down and spin it up and this is what I've ended up so far;
not the best pic.
The "machined" ends are 9.5mm and 10.5mm so once I get it in a real lathe hopefully I'll have something I can use :) .
PostPosted: Mon Jun 24, 2013 7:54 pm
yes, get one the same size as the hole.... measure it cos I can't remember
PostPosted: Mon Jun 24, 2013 10:24 pm
kenno
Contact theminiman, matt might sell you a couple of cast iron studs for those holes.
Dalmeny
PostPosted: Wed Jun 26, 2013 5:50 pm
Where can I get more/new main bearing cap bolts :?:
PostPosted: Wed Jun 26, 2013 6:52 pm
Only use ARP bolts throughout.
Grant
100% Pure A Series Turbo
PostPosted: Thu Jun 27, 2013 5:27 pm
Cut off the bolts, but still need to finish the cast iron studs which should hopefully be tomorrow.
PostPosted: Thu Jun 27, 2013 6:28 pm
what sealant/thread locker did you use for this?
Grant
PostPosted: Thu Jun 27, 2013 9:20 pm
I forget exactly. It's a type of component sealer and it's green.
My brother is a mechanic (15 years) and he said it will do the job so fingers crossed :lol: .
PostPosted: Fri Jun 28, 2013 8:04 am
looking good Kenno,,, just that if you`re using the 8v head then you will probably want to block off the oil gallery too (front of block , exhaust side) if you ran with a 16v head then you could use it,,, but on the 8v head there`s no meat in that area to be able to use it.
& i use Bens lovely alloy dissy-hole bungs too :-) great work Ben
Users browsing this forum: No registered users and 125 guests
