It is currently Sun Jul 20, 2025 3:30 pm
 Post subject: Terminal block cover
PostPosted: Thu Jun 27, 2013 4:55 pm
Is there such a beastie as a terminal block cover or do you have to do a home made jobbie? I have been poking around but not coming up with anything?
For some reason i would feel better with something covering it when I drop spanners/screwdrivers :lol:
CJ
PostPosted: Thu Jun 27, 2013 5:06 pm
You can get a rubber end for the power leads that covers the individual terminals, same as a battery terminal.
PostPosted: Thu Jun 27, 2013 5:38 pm
this would work a treat http://www.ebay.com.au/itm/CLASSIC-CAR- ... 553&_uhb=1
PostPosted: Thu Jun 27, 2013 5:53 pm
Maybe just turn it upside down so the terminals aren't exposed?
Jacob
PostPosted: Thu Jun 27, 2013 9:54 pm
If you have an Auto Electrician close by , ask them , they should be able to help .
 Post subject: Rubber Boot
PostPosted: Fri Jun 28, 2013 5:39 am
The Original battery cable used to have a rubber Boot on it but they are always very hard and brittle to move from one cable to another Probably a visit to a wrecking yard will get yourself one off a later model car which will be soft and usable. You can try and re use an old one by soaking it in boiling water to soften it then slip it of old cable and on to new one. Make sure you disconnect battery before you attempt this. Good luck.
"Let us remove your "SHORTS"
PostPosted: Fri Jun 28, 2013 8:45 am
I leave mine nekkid, makes it easy to connect the battery charger up if needed. :lol:
PostPosted: Fri Jun 28, 2013 10:19 am
I always find that once you pull back the old boot to undo the nut they are so stuff that they are pretty well impossible to get back over the terminal again. The always end up pulled back up the cable.
You can get modern ones that are a sort of silicone material that would probably stay soft.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jun 28, 2013 10:46 am
I just got a new battery cable made up at Battery World. They have those plastic blister packs with nice new and soft terminal covers. One red and one black per blister pack. Cheap as chips. I actually can't recommend Battery World in Albion enough, they were very helpful making my cable that is actually 2 with room for a battery isolator in line.
Users browsing this forum: No registered users and 68 guests
