It is currently Sat Jul 12, 2025 7:35 am
 Post subject: Camshaft ID?
PostPosted: Mon Jul 01, 2013 5:30 pm
How can I identify camshafts?
What numbers should I be looking for and any other obvious things that help tell them apart (eg say a 998 cam from a mk1 S cam)?
PostPosted: Mon Jul 01, 2013 6:42 pm
Numbers, lobe size (width), drive, number of rings. Grab a Vizard book. It will help identify factory cams.
PostPosted: Mon Jul 01, 2013 7:29 pm
small-bore cams are normally narrow lobes (3/8"ths) & pin-drive-->, except the Late A+ 998 which are slot/spade drive
1100"S" cams are all wide lobe 1/2" & are spider drive
Cooper"S" are wide lobe & pin-drive
Late 1275 A+ are all spade-drive wide lobes
If you are planning on finding a suitable cam for your twinky to grind all the lobes off, then maybe a spade drive cam as they`re easier to find,,, easy to get oil pumps to suit,,, & also fit the block you`re using too :-)
PostPosted: Mon Jul 01, 2013 7:38 pm
If you find any narrow lobe spider drive cams, they came out of a 998 auto or 1098 auto.
PostPosted: Mon Jul 01, 2013 7:45 pm
cooper s cams dont have the fuel pump lobe , well mine didnt
PostPosted: Tue Jul 02, 2013 8:34 am
David Vizard's book "tuning the A series engine" has an excellent table for identifying factory camshafts including the performance cams available from the factory.
1962 Mini Speed sports sedan
 Post subject: Cam shafts.
PostPosted: Wed Jul 03, 2013 10:19 am
I have always wondered about a particular Cam shaft that I have which is spider drive type and 3/8 lobe. What would it's origin be?
"Let us remove your "SHORTS"
 Post subject: Re: Cam shafts.
PostPosted: Wed Jul 03, 2013 11:36 am
Automatic 998 mini or auto Morris 1100 (1098) for sure. The autos all got spider drive until 1980 because of their HUGE oil pump.
A pin drive would shear off driving that pump.
I have no idea what the Rover automatics have from 1980 on, whether still spider drive or they went to slot drive.
 Post subject: Hmm!
PostPosted: Wed Jul 03, 2013 5:02 pm
Thanks Kev Now I know what it is from.
