It is currently Mon Jul 14, 2025 6:13 am
 Post subject: Storing an engine
PostPosted: Tue Jul 02, 2013 5:36 pm
I have removed my 1098 engine, which is now sitting on the floor as a complete power unit. Oils been removed and coolant has been emptied.
Do I need to do anything special to preserve it?? (it is a newly built unit that has done less than 3,000 miles.)
Dalmeny
PostPosted: Tue Jul 02, 2013 5:56 pm
I'd leave oil in it to protect the gears, a spray of oil in each bore & all holes blocked up. Wouldn't hurt to turn the crank from time to time. Have successfully stored this way many times.
Ash.
PostPosted: Tue Jul 02, 2013 7:08 pm
I would leave oil in it too
PostPosted: Tue Jul 02, 2013 7:19 pm
I would leave fresh CLEAN oil in it. Any cheap stuff will do fine.
Dirty oil is acidic and will etch the needle roller bearings etc if stored long enough.
As I found out once when I bought a 10 year stored engine with dirty oil in. I had to change every bearing in the box.
PostPosted: Tue Jul 02, 2013 7:39 pm
yep^^^ what he said^^^ for sure,,, dirty acidic old oil will eat the teeth on the gears & the bearings & & & & &
flush it all out & fill with fresh clean new oil & I`d even try to get some STP on the bores
High heel ninja
Make sure the block is completely drained of water/coolant.
Doogie
PostPosted: Tue Jul 02, 2013 7:46 pm
What are you doing with the engine dalmeny
PostPosted: Tue Jul 02, 2013 8:44 pm
Was told to fill with diesel, never tried it though. :shock:
1993 R32 Nissan Skyline GTR
PostPosted: Tue Jul 02, 2013 9:05 pm
Diesel will find its way out & end up on the floor!
PostPosted: Tue Jul 02, 2013 9:14 pm
Thanks
I'll do everything mentioned above. (Maybe not the diesel)
rick - the 1098 will stay with the car, so IF I decided to sell it, the new owner can choose between running the Twinky or the original 1098.
Dalmeny
 Post subject: Diesel?
PostPosted: Wed Jul 03, 2013 10:23 am
Diesel will also swell pp and ruin all rubber seals.
"Let us remove your "SHORTS"
