It is currently Mon Jul 14, 2025 8:37 pm
PostPosted: Fri Jul 05, 2013 11:36 pm
I'm interested in putting electric windows in my clubman.
I know people have done this and has been discussed before. But I did a search and couldn't find it
So What kit did people use and how did they do it.
Thanks Bubba
PostPosted: Sat Jul 06, 2013 8:03 am
Mods rock!
Yeah, I've done it a few times, easy. No kit. Works a treat.
PostPosted: Sat Jul 06, 2013 10:33 am
Hmmm,well that doesn't help me any.....
if you dint buy an electric window kit where did you get the parts?
I remember ages ago looking up a kit someone posted up (obviously not a specific mini kit, but a universal kit that was easily adapted).
PostPosted: Sat Jul 06, 2013 11:21 am
1 of those universal kits off ebay type of thing?
maybe this could work
http://www.ebay.com.au/itm/ROVER-MINI-E ... 257405d5dd
PostPosted: Sat Jul 06, 2013 1:31 pm
People have done it a few ways before. GTs above uses the original regulator, probably with the electric window motor from a small car welded to the input pinion.
If you have the skills to make something like this its probably the best solution.
I know Archangel used a generic kit (SPAL possibly) so flip through his El Gato thread for photos, and I have the SPAL kit in my car and they work fine, not quite OEM looking and bit of work to fit - but they are universal to nearly anything. Good thing about them is if something goes wrong the repair mission is pretty easy.
The universal kits adapt to the crank input of the original regulator, so this must be in good condition in order for the arrangement to work properly.
The rover/mayfair kit in the above post is pretty much useless to an aussie car. Its for UKmk3 types onward - those doors are wider inside and don't have a regulator mount welded onto the doorskin like aussie cars. You could probably adapt it but would be a pain.
Before I went with the SPAL kit, I looked at using the scissor type levers from small cars, but found them too bulky, and I also looked at hot rod kits which look very simple to install, except they're pretty big heavy construction, and again, really too tricky to cram in.
PostPosted: Sat Jul 06, 2013 6:00 pm
this spal kit? http://www.ebay.com.au/itm/SPAL-2-DOOR- ... 2ebb5a3892
PostPosted: Sat Jul 06, 2013 6:25 pm
Yep that looks like the one I got.
PostPosted: Sun Jul 07, 2013 11:48 pm
Excellent!
Thanks everyone for there comments/recommendations.
I think the SPAL kit is the way to go.
Bubba
PostPosted: Mon Jul 08, 2013 7:30 pm
I'm thinking of doing this at some point, if there's not one already, would you care to put up a build/Installation thread?
So what's the last thing you remember...
I'm pretty sure you were..
WRONG ANSWER!!!
PostPosted: Mon Jul 08, 2013 7:39 pm
Ahhahh!!
Here is the one from Archangel:
http://www.ausmini.com/forums/viewtopic ... i&start=15
PostPosted: Mon Jul 08, 2013 7:47 pm
Bubbacluby wrote:
Ahhahh!!
In short, Look first.. :lol: :oops:
didn't remember seeing that one..
Cheers Bubba.
WRONG ANSWER!!!
PostPosted: Sat Jul 13, 2013 6:08 pm
I used a kit similar to this, Does away entirely with the original mechanism and fits behind a stock door card. So less chance of mechanical failure, It was not easy to install either.
