It is currently Sun Aug 24, 2025 12:15 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 19, 2013 10:21 pm
I flush the whole system with metho - basically fill it all up with metho, leave it in there a few days, drain it, flush it again then run clean fluid through - amazing amount of gunk comes out
IndigoBlueCooperS wrote:
I thought that the 15/16 cylinders had a slightly different bolt pattern to the 1 inch ones. The cylinders need to match the backing plate, unless you want to file out the backing plate holes to match the other cylinders. Early Minis were 1 inch, and latter ones were 15/16. Changeover was in the early clubman range somewhere. I could be wrong as it is a long time since I have played with front drums.
I recently did some wheel cylinders on a clubman that had 1" cylinders in there, so I replaced them with new 1" cylinders - still had to file the holes a bit
PostPosted: Tue Aug 20, 2013 8:08 am
Online
I think the backing plates are all the same, it's the aftermarket cylinders' bolt spacing that is the problem.
PostPosted: Tue Aug 20, 2013 8:17 am
There is nothing wrong with the wheel cylinders.
In about 1974 Leyland changed the stud pattern and backing plates when they introduced 15/16" wheel cylinders to replace the 1" wheel cylinders.
To stop people replacing a 1" cylinder with a 15/16" cylinder Leyland changed the stud pattern slightly. This was a safety measure.
People are too quick to always blame the replacement part.
PostPosted: Tue Aug 20, 2013 8:22 am
Online
Why did they change the wheel cylinder size? Were the brakes too good with 1" ones?? :lol:
PostPosted: Tue Aug 20, 2013 11:46 am
I got an email from karcraft this morning mentioning standard drums and wide drums to suit flares , which has me a little confused.
Will standard drums with A08's fit under my gaurds " no flares needed " ?
And is there any benefit from the wide drums over standard ?
Cheers Bill
PostPosted: Tue Aug 20, 2013 1:05 pm
Online
Cheers Bill
The `wide' aka spacer drums are same as Cooper S rear ones. They will give you the same track as a Cooper S. Were used front & back on Clubby S (which all had flares).
Whether legal without flares depends on the wheels. eg LS offset Contessas would be fine, standard Mini offset Contessas would not.
Internally, the drums whether `wide' (spacer type) or not are all the same diameter & width.
PostPosted: Tue Aug 20, 2013 1:50 pm
Dearest parts on brakes are the back plates and the spings that go on the front wheel cylinders
If your gonna use the plastic .700 master cylinder get the 15/16 wheel cylinders as 1' wheel cylinders dont work the best on a .700 master cylinder
I changed every thing from the master cylinder down
Im just waiting for the handbrake levers smu10005 <a> have they come in mr karcraft they were on back order they there yet
PostPosted: Tue Aug 20, 2013 2:07 pm
Cheers Bill
And you'll need some longer wheel studs if you have the standard short ones
PostPosted: Wed Aug 21, 2013 2:00 pm
Cheers Bill
Thanks Kevin as always your expierence and knowledge are invaluable to myself and many others here , so thank you very much.
Thanks yeah i have the plastic ones will go the 15/16 then
Thanks for all the hey guys its greatly appreciated.
Cheers Bill
PostPosted: Wed Aug 21, 2013 7:15 pm
After a couple of emails to the very helpful people at Karcraft " Tim & Greg " they have worked out what i need so i will be ordering them tomorrow.
Thanks again for the helpful advice.
Cheers Bill
 Post subject: Re:
PostPosted: Fri Aug 30, 2013 3:30 pm
I've got a Clubman S and I was just about to order new rear drums and I read this. I've got really small flares on the clubman, but they're still flares nonetheless.
Would I go for the Cooper S wide drums or stick to the conventional ones? Any idea of the dimensions I can check on my old drums to see what I've got currently?
 Post subject: Re: Re:
PostPosted: Fri Aug 30, 2013 3:37 pm
your car *should* have wide drums - really easy to tell the difference. If your existing drums have a 1" thick bit poking out of the drum where the wheel bolts on, then they're the wide ones - the wide drums just push the wheel 1" further out on each side
 Post subject: Re: Brakes
PostPosted: Fri Aug 30, 2013 3:41 pm
Spacer:
http://www.minispares.com/product/Class ... 0to%20shop
No spacer:
PostPosted: Fri Aug 30, 2013 3:51 pm
Simon and Timmy - that answered that quickly. Wides they are! That was lucky I didn't put the order through
Users browsing this forum: drmini in aust and 97 guests
