TK wrote:
The final drive could be different IE rubber Vs hardy spicer. The gear selection is a little different too. The selector must be used with the relevant g'box. Not interchangable.
Not sure what you mean by `selector'... (remote shift housing?)
The diff housing and remote shift housing of the 1100S are a bit different design to those on a Cooper S. There is a rubber sandwich plate between them and the 4 bolts are horizontal, not vertical.
It is possible to fit a Deluxe/S diff housing to an 1100S box then use the S remote shift, but the diff bearing housings need checking for size and alignment when bolted up. Some machining may be necessary, or the 2 dowels may need to be left out. But yes it has been done successfully many times in the past. I did one last year.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
