It is currently Wed Aug 06, 2025 11:46 am
PostPosted: Tue Sep 17, 2013 8:05 pm
clovus wrote:
Rhys,
Running your car that low, do you have any clearance issues with the steering?
At the moment I don't! As I'm only running 5 inch contessas and falkens!
There's about 1cm of clearance between the front of the guard and the edge of the tyre! :shock:
So going flat out around corners it's fine just have to be careful going into driveways etc!
Cheers, Rhys
1977 Leyland Mini Van - Sold
PostPosted: Wed Sep 18, 2013 3:20 pm
1cm gap there is awfully low.
You need a bit of clearance to the bumpstops, otherwise you will get skittish handling on bumps... :shock:
PostPosted: Wed Sep 18, 2013 4:36 pm
I have done some Hillclimb and club sprints but no expert on track setups but I found that 60mm top of tyre to guard works ok on the rear, a little lower at front, say 50mm. Running Yoko 32r, 22 to 24psi pressure in the rear also lessens oversteer. I also run very little negative camber but as much caster as I can without the tyre touching the guard when cornering.
PostPosted: Wed Sep 18, 2013 9:39 pm
Yeah, I did drop the tyre pressures a bit after a few laps and it helped.
Thanks for the input Matt, I remember when we set the car up, I was complaining it was so low itwas catching on the car trailer getting it on and off. You raised it up so I didn't have any issues driving around the street. I will drop it a little bit before the alignment and see what the suspension guys can do.
Is it worth getting the car corner weighted? Does it really help? Isit even relevant to a mini, or is it just something to brag about at the track?
