It is currently Thu Aug 07, 2025 5:59 am
 Post subject: reciprocating noise
PostPosted: Fri Sep 27, 2013 6:16 pm
When driving my mini with the wheel rotation I can hear a slight scrape sort-of sound.
I have figured it is something with the drive-line as sounds with the rotation of the wheels.
It doesn't get noticeable louder as I drive faster, just speeds up.
I have changed my Hardy-spicer joint that was worn and it didn't fix it
I have greased everything up.
Does not clunk going around corners
No play in ball joints
Brakes not scraping enough to make the noise.
All wheels done up tight (Don't laugh I had a noise I couldn't figure out that ended up being this once)
Cant see any boot or anything scraping on anything with the rotation of the wheel.
Wheel bearings at rear are tight and fine
Wheel bearings at front don't make noise when spinning.
So What could it be? My thoughts are
* could it be my tyres? I'm in need of some new tyres, so could it be the tread gauge bit on the tyre making it every time it hits the ground (A008 Yoko's)
*How else can you tell if front wheel bearings are gone? (I have 7.5 disc brakes) ie could it be a wheel bearing?
I don't know? What are your thoughts?
Bubba
 Post subject: Re: reciprocating noise
PostPosted: Fri Sep 27, 2013 6:49 pm
Rear tyre rubbing on trailing arms? Or one of your brake pipes/hoses?
Can you hear any noise when you jack up the car and spin the wheels one at a time?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Sep 27, 2013 7:02 pm
Tried that, And didn't notice anything. But will check those things again tomorrow.
PostPosted: Fri Sep 27, 2013 7:22 pm
when the car is jacked up, grab the top and the bottom of the wheel and try and wiggle it. when my wheel bearings were on the way out and getting noisy (same sound as you described) i could feel a tiny amount of play when i wiggled the wheels.
PostPosted: Fri Sep 27, 2013 9:15 pm
Could also be a warped disk.
PostPosted: Fri Sep 27, 2013 9:30 pm
MinisPlus
May be worth checking that the backing plates have clearance from the drums and disks.
I've had noises like this that have been from a backing plate only just touching.
How can it be rusty when it's covered in so much oil?
PostPosted: Fri Sep 27, 2013 11:27 pm
Have done this and were tight and no movement (some sideways movement though). But will check it again tomorrow
Can you tell a warped disc by looking at it?
I had my whole drive shafts pulled out and calipers removed from hubs to change driveshaft seals and didn't notice they looked warped
If this was the case it would make the noise when spinning up in the air. but I will recheck this as well.
Thanks everybody for their thoughts I will check these things out tomorrow and see if I have any luck
PostPosted: Fri Sep 27, 2013 11:59 pm
Tomboss Breweros
Tyres can make noise, drive with a passenger and windows down to try to isolate where the noise is from externally, cv boots can make noise, graphite powder shuts them up.
kimini wrote:
PostPosted: Sat Sep 28, 2013 8:37 am
Mine did this, but only when I touched the brakes. After much process of elimination I found one of the RDA rotors had 2 radial cracks... (so I binned both).
PostPosted: Sat Sep 28, 2013 8:20 pm
I would give your tyres a very close look over for a bubble/lump , i once had a weird noise like yours years ago it drove me crazy and changed a heap of parts till i noticed a lump in the wall of the tyre .... so make sure you check both sides of each tyre.
Cheers Bill and good luck .
PostPosted: Sat Sep 28, 2013 9:56 pm
Went around there today when he had it jacked up needs new wheel bearings and bottom ball joint needs attention after that is all fixed then he can c if the noise is still here
PostPosted: Sun Sep 29, 2013 7:51 pm
Well ball joints were checked again and one needed adjustment and thought the wheel bearing might be good to be replaced. Upon pulling them out the CV's were not real flash either (I assume CV's and wheel bearings would be the ones from the factory).
So replaced the lot and adjusted the ball-joint and noise has gone and is all good. So it was something there doing it.
Cheers everyone
Brenton
Users browsing this forum: No registered users and 117 guests
