It is currently Wed Jul 30, 2025 12:46 pm
PostPosted: Mon Oct 07, 2013 2:39 pm
I have a 1275 crank but cannot remember if it is large or small journal and the only number I can see on the crank is ESC1X does this number mean anything?
PostPosted: Mon Oct 07, 2013 2:48 pm
Online
That is a forging number. Look closely at the webs for a stamped on number.
If it is a big journal Oz crank it should have 12G1505 on there somewhere.
Otherwise, measure the crankpin diameter. 1.750" or slightly less is big journal. 1.625 or slightly less is a small journal.
PostPosted: Mon Oct 07, 2013 2:57 pm
I have found a similar number it is very faint looks to have been almost removed for balancing but the numbers I can see are 12G128* the last number is ground off and can't be read. Also what should the end float on the primary gear be?
PostPosted: Mon Oct 07, 2013 3:13 pm
Sounds just like my crank, 12G1288, the last 8 was barely noticeable! Small journal!
Cheers Shane
PostPosted: Mon Oct 07, 2013 3:24 pm
Online
Yep it's a small journal.
Primary gear endfloat- I aim for .004-.005".
PostPosted: Mon Oct 07, 2013 6:56 pm
The Mini King
Just a Note, On the large journal Crank, You Will often find 12G1505 OR 12G1505A Cast in the crank.
not stamped
PostPosted: Mon Oct 07, 2013 7:04 pm
What is the difference wit 1505A and 1505 ?
Always wondered that.
"Let us remove your "SHORTS"
PostPosted: Mon Oct 07, 2013 7:07 pm
Lucky i'm rebuilding this engine it's pretty shagged, at the moment primary gear is .015, and the end float on the crank is .0098.
PostPosted: Mon Oct 07, 2013 7:13 pm
Online
If you are going to rev it, I'd want .006" crank endfloat, minimum. I built my 1360 with the recommended .003" the first time, after 3 laps at a Wakefield Pk track day the oil pressure went south. It almost spun the centre main shells, and I had to regrind the S crank to clean the centre main journal up. It has .007" endfloat now, all is good.
PostPosted: Tue Oct 08, 2013 10:40 am
small journal cross drilled, large journal not. Well that's my experience anyway.
PostPosted: Tue Oct 08, 2013 11:32 am
Mine was cross drilled too, I thought it was done on a rebuild, maybe!
Maybe it was a factory job.
Cheers Shane
PostPosted: Tue Oct 08, 2013 11:42 am
Online
Some small J cranks were cross drilled when new, the later ones were not.
PostPosted: Tue Oct 08, 2013 12:02 pm
What is the standard primary gear thrust washer size I'm not sure if the current one is worn or if the engine was built incorrectly the previous time.
PostPosted: Tue Oct 08, 2013 12:04 pm
The Mini King
I do not think there is any difference, Also sometimes the A is there but not very clear
PostPosted: Tue Oct 08, 2013 12:30 pm
Online
There were lots of sizes selectively fitted.
Karcraft now lists them from .122" to .128" thick. Matt Read `TheMiniMan' also gets them made up in Brissy.
Note the steel `C washer/clip' wears more than the thrust washer, you can turn it over once to extend its life or go buy a new one.
Users browsing this forum: Bing [Bot], drmini in aust and 94 guests
