It is currently Sun Jul 20, 2025 10:41 am
PostPosted: Fri Oct 11, 2013 6:05 pm
Hi All,
Where would i get another of the copper(?) pipe that goes between the 2 wheel cylinders in a drum brake setup?
Also, we had to cut off one of the cylinder because the small bolt was rounded off, where would i get a replacement for that small bolt?
Thanks!
1975 Hairy Lime/White Clubby
PostPosted: Fri Oct 11, 2013 6:14 pm
The pipe will be steel. Just take it to any brake shop who will be able to swage you up a new one. Take the old pipe with you to get the right length. They will also have the correct fittings.
You can bend it to the right shape with your fingers. The pipe is not hard to bend, but won't collapse if you play it by ear and bend it carefully.
PostPosted: Fri Oct 11, 2013 6:21 pm
Thanks for that.
Now I just need to find a replacement for the small bolt.
PostPosted: Fri Oct 11, 2013 6:44 pm
Which bolt in particular are we speaking of? The hex fitting on the end of the pipe or an actual bolt?
PostPosted: Fri Oct 11, 2013 7:08 pm
The bolt that fixes the wheel cylinder to the backing plate. There are 2 on each cylinder. A big one and a small one I need the smaller one
PostPosted: Fri Oct 11, 2013 7:12 pm
Minispares says they're 1/4UNF x 3/8ths long. Should be able to get a similar length from a bolt rack. Perhaps cut it down with a hacksaw to get it to the right length if they're a little long.
http://www.minispares.com/product/classic/SH604031.aspx
PostPosted: Fri Oct 11, 2013 7:22 pm
Thats funny. Its supposed to be the same bolt as attaches the cowl to the radiator.
Just replaced the radiator, so I should have 6 spares.
Win!
PostPosted: Fri Oct 11, 2013 7:57 pm
make your own pipes.
easy as having a ....
It's easy once you know how.
PostPosted: Fri Oct 11, 2013 8:20 pm
I always make my own these days. Once you have the double flaring tool it's pretty convenient.
PostPosted: Fri Oct 11, 2013 10:30 pm
yeah Mick the double flare tool is better tha norm but is not fool proof either as you would know by now.
