cush wrote:
You crazy Matthews must stick together...
http://minisport.com.au/prod593.htmI'm assuming Matt (Read) your bit replaces the metal part of the above kit?
Sent from my Nexus 7 using Tapatalk
Yes.
Matt's one has the o-ring next to the shaft whereas the other common one has the o-ring next to the casing, meaning it still has a gap to allow the shaft to move.
Having said that, i have one of the common ones in mine and it has not leaked in a year. Only reason i got it was because Matt was out of stock at the time. Then he goes and modifies his design to make it removable. I think next time i change the oil i'll stick one of Matt's in because the current one will probably be leaking by then.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
