It is currently Thu Jul 31, 2025 8:56 am
 Post subject: Help - Won't start
PostPosted: Mon Jan 06, 2014 1:39 pm
G'Day,
So i drove the mini home at lunch and when i went to return to work the engine wouldn't turn over.
Noticed that when the key was in the accessories wipers, washers and gauges all worked as expected however when the key was turned to the on position none of them worked.
I assume based on this observation that its an issue with the ignition switch itself?
Is this a common issue and can anyone point me in the right direction where to look.
Thanks
Ryan.
 Post subject: Re: Help - Won't start
PostPosted: Mon Jan 06, 2014 1:46 pm
just the minis way of telling you to stay home for the rest of the afternoon with your feet up
PostPosted: Mon Jan 06, 2014 1:50 pm
I would certaily start with the ignition switch.
Take a multimeter and test the switched fuse in the fuse box. It will be Off with the key in Off. 12 volts in ACC, and 12 volts in Start. If it turns off at start then you will need to look at repairing your ignition switch.
PostPosted: Mon Jan 06, 2014 2:24 pm
Yeah that was my initial thought.
PostPosted: Mon Jan 06, 2014 2:27 pm
Righto I'll give that a shot when i get home.
PostPosted: Tue Jan 07, 2014 6:28 am
It was the wiring loom on the ignition, I pressed the individual wires in a bit harder and all is now good.
PostPosted: Tue Jan 07, 2014 8:57 am
Good stuff. The terminals on the back of the switch you mean?
This is a problem that you will probably see again in that case. At least you know where it is.
PostPosted: Tue Jan 07, 2014 9:16 am
It was on the plug that the ignition switch wires go into, i just pressed them in a bit and its been good.
Had a look in the spares i got with the mini and there is a new ignition switch among them so I would say its been playing up for a bit. I'll swap them out when i get a chance.
Users browsing this forum: Bing [Bot] and 80 guests
