It is currently Tue Jul 22, 2025 5:35 pm
 Post subject: door hinges coming loose
PostPosted: Tue Jan 07, 2014 4:43 pm
I know this has been asked before, but after a search, I can't find a satisfactory answer. How do you stop the door hinge screws from loosening on external hinge doors? would 'star' washers hold any tighter than conventional spring washers? If Loctite was to be used, which one? :?:
johnl
PostPosted: Tue Jan 07, 2014 4:46 pm
The nuts should be enough, but overtightening may pull the studs from the hinge requiring a recoil insert to be fitted.
A helicoil would make a stronger thread, and more torque can be applied to hold the door hinge straight.
Make sure you have the angled washers fitted on the top hinges, and that the nuts aren't stripped.
PostPosted: Wed Jan 08, 2014 7:08 pm
The Mini King
Also make sure You put the big but Thin washer on the rear bolt on the top Hinge
PostPosted: Sat Jan 11, 2014 7:06 am
John, what size and thickness are the 'large' washers? Do they only go under the upper hinge bolts? Do you have them?
John
johnl
PostPosted: Sat Jan 11, 2014 8:50 am
You can get them of the bolt rack at auto shops, or buy them as grab kits.
They're especially large washers with very small holes relatively to spread the load and prevent panel distortion as you tighten them down.
http://championpartsonline.com.au/index ... t_id=19609
PostPosted: Sat Jan 11, 2014 9:23 am
The Mini King
I Do Have a couple in stock I am waiting for more stock, has I have them Made
Because I have trouble buying them the correct thickness, They must be thin as they take
the shape of the door skin, They are only used on the top hinges on the rear
although some people like to use them top and bottom
If You cannot get them as suggested above Give Me a call 0427671314
or if You like send Me a PM
PostPosted: Sat Jan 11, 2014 9:34 am
Ill let you know how them pot joints hold up today john after a run to woy woy then around toukley
PostPosted: Sun Jan 12, 2014 10:12 pm
Does anyone have the angled washers for sale? I can only find 2 but need enough for 2 cars?
M
PostPosted: Mon Jan 13, 2014 4:07 pm
If you can't find any you can make them from a 1/2" aluminium rod (got this advice from here: http://www.theminiforum.co.uk/forums/to ... -14a7387/a .
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Wed Jan 22, 2014 4:38 pm
Hi John,
I sent you a pm a couple of weeks ago but didn't get a reply. I'd like to get 4 of them, if you have them please.
regards
John
johnl
PostPosted: Wed Jan 22, 2014 6:34 pm
The Mini King
lockwood wrote:
Hi John,
regards
John
Sorry I only Have Two 2/Hand ones at this point new ones arriving end of next week
Sorry I will Check My PM'S
Best Regards
John Smidt
Users browsing this forum: No registered users and 69 guests
