It is currently Sun Jul 27, 2025 9:21 am
PostPosted: Sat Jan 18, 2014 3:19 pm
G'day,
Found that at normal pressure (28 psi) the Falken 165s stick out 17mm from the rim, while the Bridgestones only stick out 4mm!
Could anyone with Mambas 10 x 6 (mine are original ones) who have A008s on please measure and let me know, as thinking of getting a set and don't want them sticking out like the Falkens......
Thanks in advance.....
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Jan 19, 2014 2:14 pm
Do you mean the sidewall to the lip of the rim? I have the new style mambas with 165/70 A008's. At 26 psi the sidewall sticks out 2mm.
PostPosted: Sun Jan 19, 2014 5:59 pm
Yep,
Sidewall to lip of rim. Thanks for that. Appreciate your help. I had heard that the 008s are not super wide and this confirms it.
Hope this info also helps others!
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Jan 19, 2014 6:31 pm
I have original Mamba's with A008's , and as best as i can measure = 18mm .
PostPosted: Sun Jan 19, 2014 8:06 pm
The new ones must be quiet different from the originals!
PostPosted: Sun Jan 19, 2014 8:36 pm
Oh....
The new Mamba 6s are listed as ET (offset) -7. I will try and measure my originals offset tomorrow and post it up.
Thanks guys.
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Jan 20, 2014 7:00 pm
I don't think the offset would affect it much, more the design of the lip and bead seating?
maybe i'm measuring the wrong thing, is this how everyone else is doing it?
PostPosted: Mon Jan 20, 2014 7:49 pm
Hi JimL,
Duh....been a busy 2 months at work and my brain hurts!!!
You are right....offset means SFA.....
The method you show is the method I am using so will be a valid comparison. Was checking offsets as wanted to reduce any tyre sticking out from flares, and so I could see the difference in different wheels as well as different tyre overhangs.
Thanks again.
Cooper S Mk2
Cooper S Mk1
