It is currently Mon Jul 21, 2025 11:28 pm
PostPosted: Wed Jan 29, 2014 8:00 pm
Hey All,
The rear exhaust mount snapped the other day, it looks like its been welded up previously...
my problem is, the loop part that goes around the pipe has been welded on... how should I get the old part? just grind it away
also, can i disconnect the last section of the exhaust, by undoing that U bolt, or will it be welded there also?
thanks!
1975 Hairy Lime/White Clubby
PostPosted: Wed Jan 29, 2014 8:03 pm
You should be able to remove the last section of the pipe as you say. I would just carefully grind that old bracket of and replace it with a new one.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Wed Jan 29, 2014 8:48 pm
u bolt should be fine maybe a exhaust shop might have the correct diameter pipe and bend you one up im having trouble getting the front section from manifold to the muffler im thinking of doing the same thing going to a exhaust shop and having one bent up mines welded where it clamps to the diff section and you cant get that pipe in aus no more so ive been told from a few sources
PostPosted: Wed Feb 05, 2014 10:32 pm
http://m.ebay.com.au/itm?itemId=300868881115
This is at seven hills nsw if you still need one
PostPosted: Thu Feb 06, 2014 6:08 pm
Grind the old bracket off, when you undo the u-bolt the pipe may be a bit rusted into the muffler so it can sometimes prove a PITA to get apart.
PostPosted: Thu Feb 06, 2014 6:26 pm
I'd get thee to an exhaust shop and ask for a new tailpipe to be bent up. Then fit a new clamp and mount.
A Cooper mount bracket setup is stronger (has 2 rubber mounts not 1).
PostPosted: Thu Feb 06, 2014 9:12 pm
The trick is not to tighten the bracket too tight, it'll allow for movement and also the exhaust actually moves back and forth with engine movement, not sideways like say a holden/ ford. The pipe also gets longer as it heats up.
PostPosted: Fri Feb 07, 2014 5:13 pm
the faster you go the longer it gets ??? :) :) :)
65 panel van Sprog
73 panel van Iggy
