It is currently Sat Jul 19, 2025 9:04 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Feb 25, 2014 8:44 pm
if the clutch is leaking however, it won't allow the clutch to disengage, but also won't cause over extension as has happened here.
Was the bearing pushed up hard against the carrier shoulder when it was put in?
Apart from the clutch arm wear, other items to look at are the top and bottom clevis pins, or damage to the clutch spring plate where the bearing contacts the plate. I haven't heard of the clutch arm bending under load...but it might also be worth a look?
Definitely time to remove the wok for a look see however...
PostPosted: Tue Feb 25, 2014 8:53 pm
simon k wrote:
the arm etc. wouldn't degrade that quickly, sounds more like something leaking
Well thats what I thought but I'm seeing good movement of the slave, no visible leaks, pumping made no difference.
I could see that the plunger was hitting the circlip. As soon as I removed the circlip and gave a bit more adjustment it felt normal all the way home.
When I first posted I replaced most links. I'm expecting to see massive wear in the plunger. I guess the ball could be cracked but as I say it is one of the new thick arms.
Yes the bearing would have been fully home, it was all operating perfectly when new plunger etc. was installed.
PostPosted: Tue Feb 25, 2014 9:37 pm
I have an original carrier, I will borrow a Karcraft one on Monday and test the hardness on both. The Kc one is supposed to be EN24 = good stuff.
I tested an original, it was over 50HRC.
I tested 2 KC ones a month ago, they were about 1 and 2 HRC... :shock: They were told the material was EN24 but apparently it was not the case.
These appear to be made from Ledbrite free machining steel then plated, not hardened. Can't heat treat this stuff...
Kc has some real `EN24' (hopefully) ones coming from UK in the next shipment.
I have since saved 2 soft ones by drilling the hole to 9/16" diameter then press fitting hardened silver steel bushes I made.
PostPosted: Wed Feb 26, 2014 6:36 pm
How new/old is your engine? About 3 months ago I decided it was time to rebuild my engine (at this time the clutch was almost non exsistant), upon dismantling the engine I discovered the end float was nearly 3 times spec and as I put my foot on the clutch it was pushing the crank towards the radiator, stopping the clutch from disengaging.
PostPosted: Wed Feb 26, 2014 7:52 pm
I think you will find the plate that the bearing presses against will have a groove worn in it.
Any way hurry up and remove the wok as we are all eagerly waiting for the answer.. :lol:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 26, 2014 8:16 pm
That is another recent problem.
2 AP orange dot diaphragms I bought in the last 18 months had soft thrust plates. They need to be hard. Try a file on the corner, if you can file it, swap the plate with an old one.
it's about time some of the UK parts suppliers exercised a bit of Quality Control instead of shipping us rubbish. :evil:
PostPosted: Wed Feb 26, 2014 9:06 pm
Mspares supply (or used to) a heavy duty shuttle that had a slot rather than a cylindrical drilling ..and a matching clutch arm with a wide cam like end rather than a ball. = massive increase in contact area between arm and shuttle bore.... = equivalent reduction in point load between the faces.
Cheers, Ian
PostPosted: Thu Feb 27, 2014 6:17 am
Cheers, Ian
They also list 2 standard design plungers- an EN24 one, and a cheap minispares one which is rubbish, as mentioned in this thread- basically it's a zinc plated turd.
WHY do people continue to sell parts that are clearly inadequate and unsuited to purpose.. :evil:
PostPosted: Thu Feb 27, 2014 11:42 am
I was got caught out with a gearbox layshaft from the UK that wasn't hardened properly.
Only lasted 2000km before it went and put metal throughout the engine and gearbox.
PostPosted: Thu Feb 27, 2014 12:40 pm
Sourced from the UK, but made in one of those SE Asian sweatshops, I'm betting............... :roll:
PostPosted: Thu Feb 27, 2014 9:07 pm
Cheers, Ian
because they shipped in a container load from china and still want to make a quid out of it
PostPosted: Fri Feb 28, 2014 2:48 pm
I think I know why I lost my clutch. Although I suspect the soft thrust bearing carrier has worn so much and had been adjusted so far it jammed and snapped. I'll hopefully get the wok off over the weekend.
PostPosted: Fri Feb 28, 2014 3:27 pm
Oooohhh....
Now we all know!
PostPosted: Sat Mar 01, 2014 7:21 pm
Ok wok off. The thrust plate on the pressure plate is fine. Thrust bearing fine. removed the carrier and removed the broken ball.
The wear on the thrust bearing carrier is incredible. In the pictures you can see there is a second mark, this is where the broken off the arm was pushing against the bearing carrier after the ball broke. Maybe the arm was bent or broken for a while and it left a second mark, although I suspect it broke when I broke down and couldn't get any clutch. When I over adjusted it in an attempt to get home the broken end was pushing on the side of the opening. I'm amazed I got home with it like that.
In the last picture I have pushed an Allen key into the divet from behind to show how deep it is.
I have a new "soft" bearing carrier into which the good Dr. Mini has inserted a hard steel bush. Just waiting on a new bearing and should be all good.
PostPosted: Sat Mar 01, 2014 7:26 pm
Pieces of crap!
Users browsing this forum: No registered users and 70 guests
