It is currently Wed Aug 06, 2025 5:28 am
 Post subject: Dodgy Alternator?
PostPosted: Sun Mar 16, 2014 2:45 pm
Hi
I've got a 17ACR alternator which I've had in my car for years.
The other night I noticed that the ignition warning light was slightly glowing. It cut in and out a couple of times but was generally glowing.
I checked the voltage from the terminals on the alternator and was getting 14.62 at the two bigger connectors and only about 10.8 volts from the little one (which I believe goes to the warning light).
Does anybody have any idea what this means?
I read on one website http://www.mgb-stuff.org.uk/electricstext1.htm#faults, specifically http://www.mgb-stuff.org.uk/electricstext1.htm#diodesthat this might indicate that some of the diodes in the alternator have packed it in.
 Post subject: Re: Dodgy Alternator?
PostPosted: Mon Mar 17, 2014 8:15 am
If it's intermittent, I'd guess that it's the brushed getting short - they won't always get a good contact. Or do you mean they glow when the car is off? Then it's the diodes ;)
14.6V is a bit high - I'd be worried about overcharging your battery at that voltage. It shouldn't do much more than shorten the life of your battery, but a modern alternator will sit at around 14V.
My old 18ACR? put out 14.5, and it was playing up a little, so I swapped it out for one of convertable mini's alternators (he's a member here) and it's been working fine since. If you're reading 14.6V, and your diodes need replacing, I'd just get a upgraded alternator with a good transistor regulator (read: any newer alternator).
If you do want to re-do yours, you can solder new diodes in yourself cheaply and easily, but the regulator is non-serviceable, and you may need to get a new one.
PostPosted: Mon Mar 17, 2014 9:02 am
Hi Mr Yobbo,
Thanks very much for your reply.
I've PM'd Convertible Mini to check on costs etc. and have also been talking to John Smidt about whether it's worth a repair.
I might have to go the new path as I'm a crap soldlerer.
Thanks again,
Users browsing this forum: No registered users and 62 guests
