It is currently Sun Jul 20, 2025 1:33 am
PostPosted: Sun Apr 20, 2014 4:27 pm
I have just fitted the bottom rad hose to my 1360 mini engine.
The mini spares hose appears to be to short at the pump and radiator end. I would say 20mm each end.
Has anyone come across this. The hose touches the timing cover.
For reference the timing cover is the one with the breather.
Not happy Jan.
 Post subject: Re: radiator hoses
PostPosted: Sun Apr 20, 2014 6:46 pm
If you buy from Karcraft in Sydney they have `Mackay' Oz made ones still (I think).
They fit fine, but most of out cars (except 1275LS and late 1275 Moke) had no timing cover breather.
PostPosted: Sun Apr 20, 2014 7:19 pm
I got one a couple of weeks ago from karcraft they are still Mackay ones I havent fitted it yet (a new born slow progress down) but it looks about right.
PostPosted: Sun Apr 20, 2014 9:06 pm
Heres a photo
Its very close to the timing cover
PostPosted: Sun Apr 20, 2014 9:41 pm
As long as the hose is securely on the water pump and radiator i wouldn't worry about it. In this case with the mini, the radiator is mounted to the motor, so any movement should be shared and there should be no rubbing of the hose, touching maybe but no rubbing.
I don't see it as a problem in this instance.
PostPosted: Mon Apr 21, 2014 1:39 pm
place a piece of rubber?
cut a piece of old radiator hose.
It's easy once you know how.
PostPosted: Mon Apr 21, 2014 6:10 pm
That look normal
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
Users browsing this forum: No registered users and 68 guests
