It is currently Sun Jul 20, 2025 4:54 pm
PostPosted: Wed Apr 23, 2014 9:53 pm
I just got my x pin LSD diff today. Can you change it over without taking the engine out?
PostPosted: Wed Apr 23, 2014 10:09 pm
Short answer no
Long answer you should probably take the engine out because you would have to be pretty creative to do it in the car.
PostPosted: Wed Apr 23, 2014 10:58 pm
The diff cover draws out on long studs. The cover will only move a little way before it would foul on the subframe.
PostPosted: Thu Apr 24, 2014 6:42 am
Thanks for the replies. Looks like I will add engine removal to the list then. I'm guessing if you jacked the car up high enough, it would be possible to swing the whole assembly down enough to get those bolts free? Then it would only be engine mounts that need to be done.
PostPosted: Thu Apr 24, 2014 8:56 am
No Clive, it`s actually more work to get it out while it`s in the car
best to just pop the donk out, swap the diff over on the bench & then
shove the donk back in
i can help you out sometime next week if that`s any good to you?
PostPosted: Thu Apr 24, 2014 9:43 am
cross pin OR LSD ?
not the same thing... your normal minisp*** cross pin differentials aren't limited slip
PostPosted: Thu Apr 24, 2014 8:01 pm
Ahh well that's what is is Simon then. Thanks, for clarifying that.
Thinking about it, it is really easy to get it out. I just drop it off to the mr magic miniman and hey presto I get a phone call to come over for a chin wag n pick it up.....how easy is that!!!
Cheers Matt, will do.
Users browsing this forum: fuzzy-hair-man and 83 guests
