It is currently Fri Aug 08, 2025 5:46 am
 Post subject: Which clutch housing
PostPosted: Mon May 05, 2014 6:26 pm
Hi all
Does anyone know if a rod change clutch housing will work on a 4 synchro remote gearbox or do I have to use the correct early housing .
Thanks
 Post subject: Re: Which clutch housing
PostPosted: Mon May 05, 2014 6:38 pm
Provided the idler gear is a match then yes. Not the other way around as the rod change transfer housing has an extra bit cast into the housing at the bottom to prevent shift overthrow.
Steve
PostPosted: Wed May 07, 2014 12:09 pm
Thanks Steve
Users browsing this forum: Bing [Bot] and 96 guests
