" width="1024" height="768"
Doc,
you have your dwell set too high at the lower revs... this will be overcharging your coil and just causing heat.. Also you can give more dwell at higher RPM... its one of the great features of the Black Box...
Here are some figures to play with...
Just working on the Dwell graphs and knowing that a typical GT40 coil charge time is around that 7 ms......
RPM........Distributor RPM.........RPSec......... Each Rev........... time For 4 cyl (90 degrees)
1000.........500..........................8.33.........120mS...................30mS
2000.........1000...........................................60...................... 15
3000.........1500..........................25............. 40.......................10
4000..........2000...........................................30.....................7.5
5000.........2500.........................41.67...........24...................... 6
6000..........3000............................................20......................5
7000..........3500...........................................17......................4.2
8000..........4000............................................15.................... 3.8
90 degrees = 100% (ED.. I note that your dwell is in degrees. I must have the old software as mine is in %ages)
Rules as per the instructions. Not less that 25%. Not more than 75%
RPM For 4 cyl (90 degrees) % on graph Coil charge time achieved (Optimal 7mS)
1000................30mS ................25%(min)............................7.5mS
2000................15.....................47%.....................................7mS
3000................10.....................70%.....................................7mS
4000................7.5....................75%(max).............................5.6mS
5000................6...................... 75%(max)............................4.5mS
6000................5 ......................75%(max)............................3.75
7000................4.2.....................75%(max).............................3.15
8000................3.8.....................75%(max).............................2.85
These numbers are from Accuspark.....
Sports Coil 7mS to draw peek 2.5-3amps
5mS will draw just over 2 amps which is over an 80% total charge. (remembering the coil charges fast initially. see graph)
dwell % Revs Charge time mS
10.............500.............7
.................1000.............5
20.............1000.............7
.................1500.............5
30.............1500.............7
.................2000.............5
40.............2000............. 7
.................2500.............5
50.............2500.............7
.................3000.............5
60.............3000.............7
.................3500.............5
70.............3500.............7
.................4000.............5
Interesting note... Mini points dwell is usually set at 58 - 60 degrees
(~66%) or optimized around that 2700 rpm where a mini engine would spend most of its time.
