It is currently Tue Jul 22, 2025 12:25 pm
PostPosted: Mon May 19, 2014 3:52 pm
What are peoples thought regarding the water heated manifolds?
It's easy once you know how.
PostPosted: Mon May 19, 2014 4:14 pm
I'd not bother heating it unless you live in Tassie, or maybe the Snowy.
Most people don't hook it up, unless you get carb icing inside.
[edit] Having said this, YES, I am going to water heat my Weber manifold, because I get carb icing in the Dellorto when cruising at 110KMH or faster. But I'll put a ball valve on so that for non-freeway use, it can be turned off.
Last edited by drmini in aust on Mon May 19, 2014 8:09 pm, edited 1 time in total.
PostPosted: Mon May 19, 2014 7:49 pm
I took my mini to Len reed (racepoint developments) today and that was the first thing his going to pull off... Engine came from the motherland so it's needed there but not here.
64' 850 1275cc
PostPosted: Tue May 20, 2014 11:43 am
I run one on my Moke. I haven't had any problems with carb icing since fitting it. Its quite exciting when you are travelling at highway speeds and you run up behind a slower car with the throttle frozen wide open.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
 Post subject: Queenstown.
PostPosted: Tue May 20, 2014 3:03 pm
Yep I had the same problem in Tassie, with Barney's 1293 on the run across to Queenstown. It's a bit harder to fix with twin HS4s though. :lol:
PostPosted: Tue May 20, 2014 3:21 pm
all of our cars run them down here in mexico still gets cold enough at 5 in the morning on my way to work to get the occasional hiccup
65 panel van Sprog
73 panel van Iggy
 Post subject: Re: Queenstown.
PostPosted: Tue May 20, 2014 6:30 pm
Twins SU's are a pain Doc. Here in Canberra my twins ice up all the time. Usually have to pull over and let it idle for a bit. The heat off the extractors helps. Just glad it's not a daily driver.
1963 Morris 850
PostPosted: Tue May 20, 2014 6:42 pm
You could weld a bit of 3/8" alloy tube along the balance tube, like I'm doing with the Redline Weber manifold next time it comes off.
You only need to weld it on above the 2 inlet ports where heat transfer is needed.
PostPosted: Tue May 20, 2014 6:45 pm
Great idea. Thanks.
1963 Morris 850
Users browsing this forum: No registered users and 70 guests
