It is currently Mon Jul 21, 2025 4:33 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 21, 2014 2:53 pm
If you use it, the cooling system has to be completely devoid of water. Or words to that effect on the label.
PostPosted: Wed May 21, 2014 3:57 pm
Here's what Jay Leno (a true car guy) has to say about the stuff:
https://www.youtube.com/watch?v=t7PykrgzWPQ
PostPosted: Wed May 21, 2014 6:23 pm
Just watched the Jay Leno link. They quoted that it can tolerate 3% water left in the system. So the heater would need a good drain.
PostPosted: Thu May 22, 2014 8:56 am
I have never had problems with well maintained water/coolant cooling systems and I don't really know why you would want to re-invent the wheel with a 40 plus year old cast iron motor. As the saying goes "if it ain't broke don't fix it"
PostPosted: Thu May 22, 2014 9:15 am
some glycol based coolants will eat away at parts if run neat.
cant remember what ones though.
It's easy once you know how.
PostPosted: Thu May 22, 2014 9:35 am
One of my old motorbikes needed to run on glycol free coolant as it ate at the ceramic seals.
/shrug
You're so square
Baby I don't care
PostPosted: Thu May 22, 2014 3:20 pm
there is also a class of non glycol coolants that used to be specified for racetrack applications..... spillages etc didn't create a slippery part of the track, such as Penrite 10 10th Race Coolant http://www.penriteoil.com.au/products.php?id_categ=7&id_products=482 .. this doesn't seem to be required or enforced any more...? don't know of their effectiveness/efficiency
PostPosted: Thu May 22, 2014 11:56 pm
/shrug
Old neighbour stuffed their welsh plugs in a commodore they used to fill it with coolant they put in coaches. He was a bus driver.
PostPosted: Fri May 23, 2014 12:02 am
I'm not very good at catching my coolant, and its too expensive to let dribble down the driveway!
PostPosted: Fri May 23, 2014 7:31 am
every time I've tried buying 10 10ths everyone denies it's existence.
Now there is penrite sin, not sure if it's the same
You're so square
Baby I don't care
PostPosted: Fri May 23, 2014 7:40 am
I tried it in my old VW beetle, it leaked out.
PostPosted: Fri May 23, 2014 8:57 am
penrite sin is the same as 10 10th,
PostPosted: Fri May 23, 2014 2:21 pm
Forgive the noob question but do Minis/ older cars require different coolant to newer cars.. I have 5lts left over from my commodore can u use that in my mini ??
64' 850 1275cc
PostPosted: Fri May 23, 2014 4:18 pm
Give Ash some flowers Nick .
Yes you can use it but I never mix coolants. If you don't know what is in your mini / how long its been in there flush the entire system and fill with the left over coolant from your crummydore.
PostPosted: Fri May 23, 2014 6:29 pm
Users browsing this forum: Bing [Bot] and 83 guests
