It is currently Sun Jul 20, 2025 6:34 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Jun 01, 2014 1:53 pm
Mick wrote:
Mick wrote:
by a slapper do you mean the curved dollies?
Just google "slapper", what could go wrong.
Google highlights Goulburn nightlife Mick, is this what you meant? :lol:
Did it mention Dingo's?
PostPosted: Sun Jun 01, 2014 3:35 pm
This is what I mean at 1.30 but I use a file and leave the teeth on http://www.youtube.com/watch?v=S03Boudj ... detailpage
PostPosted: Sun Jun 01, 2014 7:33 pm
Well I left the pyro bottle in the cupboard, and nearly dragged out a can of freeze spray as well, but in the end I went back to good old fashioned dollies and pushed them out by hand.
It looks pretty good now. There's a light skim of blade putty, and its come out quite nicely.
PostPosted: Sun Jun 01, 2014 8:47 pm
Looks good Mick. I was told years ago that most Oz Minis got bog put in that panel down near the bottom, during production.
PostPosted: Sun Jun 01, 2014 8:49 pm
Sounds entirely possible, I've seen it too often.
PostPosted: Sun Jun 01, 2014 9:09 pm
I've been reading these posts with great interest and would like to know if anyone can suggest some good books on this subject being panel repairs, heating and shrinking etc. Maybe trade journals?
I'm sure the skill of panel beating well is not going to be easy as that is why a whole trade was devoted to it, but like many others out there I'd like to broaden my knowledge on the subject.
Brian
PostPosted: Sun Jun 01, 2014 10:26 pm
http://m.supercheapauto.com.au/Product/ ... -419/10674
They may stock it i have this book with the earlier cover and has 2-3 pics of a mini and other cars
PostPosted: Mon Jun 02, 2014 11:30 am
Skim down the bottom of this thread l bought these books on the recommendation of the store, there written in plain English and plenty of photos in colour, they were his most popular books
viewtopic.php?f=11&t=85768
1993 R32 Nissan Skyline GTR
PostPosted: Mon Jun 02, 2014 3:32 pm
Me: I wonder if it is dry yet.
Me: No.
Me: I wonder if I can buff out finger prints.
Repeat.
PostPosted: Mon Jun 02, 2014 4:18 pm
Well done with the fix, heat shrink is rather easy with the right tools.
Oxy/acetylene torch and Garden Hose trigger gun.
First make sure the panel is not coated with tar or the back has trim on it as it could catch alight.
I use a no10 tip on the oxy, a stand off of 10mm with neutral flame and heat the panel till a 20mm wide disk of panel is glowing red. Then blast it with water from the garden hose (make sure the oxy is out the way). Hold one gun in each hand or have a helper standing by. You can use several spots however try not to over lap them.
The heat expands the thickness of the panel at the spot and when cooled pulls in the metal around it at a greater rate. You can repeat this process across the panel to pull it tight. Near edges I use smaller spots and more of them. Something like your panel would have only used one spot.
This process (with a 15 tip) is also great for trailers with a stretched tub and truck sides (not aluminum ones though) actually it's so easy to be fun. The results are really impressive once all the spots have been sanded clean and painted/coated
PostPosted: Mon Jun 02, 2014 5:04 pm
Thanks Besser,
I have a door in front of the repair which could do with some de-rippling. Can this be done with a portable butane bottle? Will there be enough heat?
PostPosted: Mon Jun 02, 2014 8:00 pm
Here's my carbon heat shrinker for the MIG. I copied it from the option pic in my Kemppi welder's book.
It slips onto the MIG tip (turn wire feed off) and the bolt clamps it there.
Will work with any MIG welder, just drill the hole the size of your tip OD.
To use it, you put the carbon against the panel where the spot is wanted and squeeze the trigger. No arc, it heats the panel by resistance. If you have a spot timer the heat spots are identical. But nearly so without one.
Easier than a gas torch, IMO.
PostPosted: Mon Jun 02, 2014 8:28 pm
I need to pick up a MIG one of these days...
I used to be able to borrow a good unit..
PostPosted: Mon Jun 02, 2014 8:35 pm
Tempory issue??
PostPosted: Mon Jun 02, 2014 8:51 pm
It could be if I just laid down the cash :lol:
I promised myself the next major project I would get a MIG. I had access to a very nice unit care of VIC Rail when I was down in Melbourne, but am in the ACT these days.
Users browsing this forum: Astroblue and 68 guests
