It is currently Sat Aug 16, 2025 6:05 pm
PostPosted: Tue Jun 10, 2014 10:23 pm
Why would the by-pass hose ever be blocked off? Is there a benefit for doing this? Should it be done? I don't run a heater at all.
What is the actual purpose of the by-pass hose??
PostPosted: Tue Jun 10, 2014 10:35 pm
The by-pass is to keep the water circulating until the thermostat opens up i believe.
Benefits for blocking it off include not having to change a blown by-pass hose.
I believe there is another reason, to do with stopping hot water from the head going back into the block.
PostPosted: Tue Jun 10, 2014 10:51 pm
As Matt said it's for circulation within the block & head before the thermostat opens.
If you get rid of it, drill a 3mm hole or two in the thermostat to allow limited system circulation.
BTW if you have a heater and the tap is on (or it's the fresh air type) you have plenty of circulation anyway. The heater circuit bypasses the thermostat.
PostPosted: Wed Jun 11, 2014 6:08 am
What are the methods used to block it off? Is it any benefit at all to cooling?
PostPosted: Wed Jun 11, 2014 7:52 am
You screw a 5/8 UNF brass plug into the head with some sealant on it.
For the water pump, you can either buy a Rover one with no bypass tee, or block it off. The neatest way to do this is tap a thread inside and screw a grubscrew in with sealant.
AFAIK there is no cooling benefit, just added reliability.
You can improve reliability of the bypass hose by using 1/2" Pirtek MPH-08 hydraulic return hose instead. It is thicker, and rated at 500psi... 8) Works for me...
I use a brass fitting in the head, they don't rust like the originals. PM me if you want one made.
PostPosted: Wed Jun 11, 2014 7:56 am
Ah righteo, I dont think Ill bother. If I remember rightly when I built the engine I used some type of heavy-duty hardcore by-pass hose that was fitted as the head went on. I would not be able to remove the hose currently without removing the head....
For me, if it dosnt improve cooling then there is no point in doing it!
PostPosted: Wed Jun 11, 2014 8:01 am
It would probably be easier to remove the water pump than the Head :idea:
If you do need to change the bypass hose, pop the water pump off, not the head.
Far less work...
PostPosted: Wed Jun 11, 2014 10:13 am
PostPosted: Wed Jun 11, 2014 10:18 am
Those dang graffiti kids got into your engine bay again I see :lol: .
PostPosted: Wed Jun 11, 2014 10:21 am
yeah, but they missed a spot, the grey bit is primer :roll:
that one was a while ago, I gave the kids a can of paint each and hung the motor up in the back yard
PostPosted: Wed Jun 11, 2014 10:25 am
I bet the clothes line didn't like that :lol: .
PostPosted: Wed Jun 11, 2014 10:37 am
:lol:
nice
PostPosted: Wed Jun 11, 2014 12:30 pm
Far less work...
Yeah I think Ill leave things as they are! Cant see that by-pass hose that I have currently failing anytime soon!
PostPosted: Wed Jun 11, 2014 3:19 pm
My metro 1300 head doesn't have a bypass at all. I drilled 3 holes in my thermostat and have never had any issues in 8 years.
Users browsing this forum: No registered users and 208 guests
