It is currently Mon Aug 04, 2025 3:46 am
 Post subject: Cold Air intake?
PostPosted: Wed Jun 11, 2014 8:17 pm
8) 8)
After removing the pancake filter I decided it needs some replacement bling!
It's easy once you know how.
 Post subject: Re: Cold Air intake?
PostPosted: Wed Jun 11, 2014 8:20 pm
Oooh! Chrome!
I hope the spark plugs short out on the foil :lol:
PostPosted: Wed Jun 11, 2014 8:21 pm
If you can't fix/make it with silver tape and cable ties...... Your not using enough silver tape and cable ties!!!
64' 850 1275cc
PostPosted: Wed Jun 11, 2014 8:31 pm
All you need now is an electric turbo on it.
PostPosted: Wed Jun 11, 2014 8:33 pm
Don't forget an intercooler
Sent from my GT-S5830V using Tapatalk 2
PostPosted: Wed Jun 11, 2014 8:34 pm
Because this time of year is when you really need a cold air intake.
PostPosted: Wed Jun 11, 2014 8:37 pm
Copy that Morris
Didn't need the tape, PVC or zip tie either!
might tape up the exhaust too.
PostPosted: Thu Jun 12, 2014 9:32 am
Hey, hows your vacuum advance on the dizzy go without a hose in it?
PostPosted: Thu Jun 12, 2014 9:36 am
There is no need for an electric turbo.
The fact that the intake pipe is bigger at the opening that it is when it gets to the filter means that the air will be going WAAAAAY faster when it gets to the carby.
I'm fairly sure its gonna give all the advantages of a proper turbo without any of the extra weight normally associated with them.
im guessing that setup is good for at least 20HP extra at the wheels
1975 Hairy Lime/White Clubby
PostPosted: Thu Jun 12, 2014 10:11 am
Is this a gee up?
PostPosted: Thu Jun 12, 2014 2:05 pm
Ram charging. Works for Suzuki SRAD bikes. --- Over 200KM/H
PostPosted: Thu Jun 12, 2014 3:27 pm
Why didn't I think of this before??
PostPosted: Thu Jun 12, 2014 3:43 pm
Hanra wrote:
Is this a gee up?
Yes
PostPosted: Thu Jun 12, 2014 4:41 pm
Note to self-
Must..modify..my..Weber..manifold..for..water..heating..before..Rylstone.
I don't need no `cold air intake', it's too cold already!
Can you say.... carb icing @ 110KMH!
PostPosted: Thu Jun 12, 2014 8:23 pm
My throttle cable froze open on the way to Bathurst due to iceing last year......
Now with 2 extra ports!
