It is currently Thu Aug 14, 2025 6:50 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: 1100 S Radiator
PostPosted: Wed Jun 11, 2014 6:52 pm
Have not reshaped top tank.
Lower mount is a 1100 mount that has been lowered. When doing this the minimal weld cracked so has been re welded.
Very easy to pull out.
I also cut a piece out of lower mount so the lower mount can stay in ppsition when removing rad. Rad comes out with top cowl attached.
The piece i cut out is so the rad lower outlet can clear the lower cowling while in place.
1 more thing. I cut the tube that the lower mount bolt goes through. Cut about 5 mm off the firewall side so rad can move back a little.
Now with 2 extra ports!
PostPosted: Wed Jun 11, 2014 11:15 pm
Hi,
ok thanks a lot, i think i got it all.
one last thing, when you lowered the lower mount... you did it just a small amount, in order to not have the fan hitting the upper cowl, right ?
Thanks
Luis
PostPosted: Wed Jun 11, 2014 11:18 pm
Yep. Not by much, but every bit of space helps....
Users browsing this forum: No registered users and 189 guests
