It is currently Wed Aug 13, 2025 9:28 am
PostPosted: Thu Jun 26, 2014 10:20 am
Can anyone who has u sed a rotisserie on a mini give me a height to the centre of the pole which runs length ways through the body. Ive been lucky enough to acquire a rotisserie used on a holden ute which needs to be modified. Thanks
1993 R32 Nissan Skyline GTR
PostPosted: Thu Jun 26, 2014 10:52 am
Rover Cooper
measure from the centre of the bonnet to the outside edge of the car and then add what you think is enough clearance for the car to be off the floor when it is sitting vertical, or work out an acceptable working height so you can stand up straight when working on the car, I have one which is identical to the car stands with a centre support with a series of holes drilled which I can push a pin into and this makes it adjustable and much more flexable, works for me.
PostPosted: Thu Jun 26, 2014 1:24 pm
1050mm is the centre height of mine, very comfortable height.
can be less if you like, I measured from the centre on a diagonal to the lower rear corners.
It's easy once you know how.
Users browsing this forum: No registered users and 256 guests
